Is 10% Ethanol a problem, can I do anything about it?
/ Is 10% Ethanol a problem, can I do anything about it? #1
smartguyz
Gold Member
Beaverton, Oregon
JD318, Power-Trac PT425 with scuffed-up green paint.
Hi guys,
For those of us running smaller gas units, like the 425 I have, is 10% ethanol a problem? I think of this every time I go to buy gas for the 425, and see that the pump says "10% Ethanol added".
I am well-aware that the Kohler (and the Robin) are designed to work with regular unleaded gasoline with no additives, to my knowledge.
I am certain that 10% Ethanol creates a hotter-burning mixture, possibly leading to burned valves and other bad things.
What say you? Any empirical evidence that this stuff is bad, and is there anything we can do about it? Additives, etc.?
-Rob :)
/ Is 10% Ethanol a problem, can I do anything about it? #2
Hi guys,
-Rob :)
I have been running all of my small engines on E10 for years with no ill effects
It's pretty tough to find fuel around here that doesn't have some ethanol in it
/ Is 10% Ethanol a problem, can I do anything about it? #3
Most of the higher octane fuels do not have ethanol - so you could use mid-grade if available.
Mike
/ Is 10% Ethanol a problem, can I do anything about it? #4
Locally, I have noticed some small individual stations are starting to offer no-alcohol gas. They advertise it that way, apparently trying to lure business away from the chains. 10% ethanol lowers mileage enough to be noticeable. I imagine some people will switch to the alcohol free stuff, if it doesn't cost too much.
Mike
That's interesting. I thought everything (all grades) had the Ethanol.
-Rob :)
/ Is 10% Ethanol a problem, can I do anything about it? #7
-Rob :)
They do here. All the common brands have the stickers on all the pumps.
/ Is 10% Ethanol a problem, can I do anything about it? #8
Interesting you say that. I just drove up to New York last night to pick up a bandsaw I got on ebay and saw lot's of stations with those sign's out in New Jersey and New York. Around here there's still plenty of stations that sell real gas so I don't have to search all around for it.
One note on Ethanol is that from some of the studies I have read it looks like Ethanol increases the amount of deposits in injectors. There are a couple of studies going on now to try to see why it is happening.
/ Is 10% Ethanol a problem, can I do anything about it? #9
Mike
In some cases the stations only have two tanks, one regular and one premium. The mid-grade is created by blending at the pump, so if ethanol is in the regular then it is in the mid-grade too, although at less concentration if the premium is ethanol free.
Interesting note- it apparently takes less premium than regular in a mix to equal the mid-grade. IOW if regular is 87 octane and premium is 93 octane it takes less than 50% premium to make a 90 octane mix.
Nice little profit center for the station owner since most charge in the middle for mid-grade, around here anyway.
/ Is 10% Ethanol a problem, can I do anything about it? #10
Back to the original question: No, E10 won't hurt your engine.
When ethanol is blended at the blender to get E5.7 (CA average) or E10, or whatever, the hydrocarbon mix is altered, including the additive packages. 87 E10 is still 87 octane. It doesn't run hotter. 100% ethanol is around 105 octane, and helps the blender "stretch" the octane components of the fuel. In California, only one supplier has ethanol free gasoline, and it is not adverised.
For those of you old enough to remember the fuss over the switch from leaded to unleaded, a similar brouhaha is going on with the inclusion of ethanol in gasoline. It is a new, to many people, fuel, and lots of odd things are being attributed to the ethanol- e.g. flying cows, off the line acceleration, pink elephants, massive HP gains, decreased fuel economy, altered emissions, kangaroos in upstate NY(to my knowledge, only the latter two or three are true).
This is a plea for common sense. Look at reviews at national organizations, like Consumer Reports. Don't believe all that you read in the media, especially the internet.
Do believe that a great number of petroleum chemists spent a lot of time and money getting gasoline ethanol blends that work. Why? Because a lot of money was riding on it.
If the fuel can be demonstrated to be bad, the oil company that created the blend is liable for the damage. Given the number of cars on the road, that is not something that they would want to have happen. I'm not saying that one brand of gasoline may or may not be better, but I am saying that if someone is disparaging the fuel, they better have real, statistical data with large numbers of engines. "Ah had a buddy whoz gran pappy had this ol engine that jus plain melted..." Don't believe me- go read data at ASME, CR, EPA, CARB, etc.
Bottom line:
  • worry about the brand,
  • worry about how fresh the fuel is, and
  • worry whether or not the stations' fuel tanks were just filled (which is bad because it stirs up debris- give it a day to settle again).
  • Don't worry about whether it has ethanol in it.
Why using brand X, my first car went 287,000 miles...Oh, wait that's anecdotal... :)
Happy tractoring folks...
All the best,
Peter
Thanks Peter,
That makes a lot of sense.
-Rob :)
David - feel free to inject nonsense.
-Rob :)
/ Is 10% Ethanol a problem, can I do anything about it? #14
Mike
I have not seen that around here.. BUT most of the station I have been around (for work) blend 87 and 93 octane to get their midgrade 89ish octane..
Looking at Bills of Ladings from terminals I also have not seen a 'mid grade' listed as being disbursed either.. Its unleaded regular and premium listed
Brian
/ Is 10% Ethanol a problem, can I do anything about it? #15
[*]Don't worry about whether it has ethanol in it.
For a frequently used engine that cycles fuel pretty quick I'd agree, for equipment that sits much of the time I'd disagree. I've also found 2 strokes really don't like ethanol gas....they run much better on pure gas/oil mix , the jetting is all wrong for anything else. Jetting is much more critical on a 2 stroke for best performance.
/ Is 10% Ethanol a problem, can I do anything about it? #16
Bottom line:
All the best,
Peter
Wow. You should be a politician. You have managed to indict those who have noticed a drop in mileage since the advent of ethanol laced gas by associating us with the outright nutcases. This despite the fact that a US gallon of 90/10 gas/ethanol mix contains approximately 4% less energy than a gallon of straight 87 octane gasoline.
So is it your theory that by reducing the energy content in the fuel, mileage will increase? Maybe those who claim you can run a car on water are on to something?
Since you are in the business of lecturing us on ethanol, perhaps you should examine some modern day ethanol politics. The reason we have ethanol fuel has virtually nothing to do with its alleged societal benefits and everything to do with pandering to agribusiness, especially Archer Daniels Midland, who owns only the finest in our politicians.
/ Is 10% Ethanol a problem, can I do anything about it? #17
How conveniant that E10 costs about 4% less than straight gasoline
Are not all alternative forms of energy subsidized to some degree?
/ Is 10% Ethanol a problem, can I do anything about it? #18
Amen brother! The whole agribusiness thing is a whole other bag of worms.
/ Is 10% Ethanol a problem, can I do anything about it? #19
Around here E10 and pure real gas are the same price.
/ Is 10% Ethanol a problem, can I do anything about it? #20
Ummm...
I don't think Peter was being political or trying to indict anybody. I got the impression he was giving his thoughts on the practicalities of running a small engine on the commonly available fuel.
BTW, I'm not crazy about the political and scientific aspects of ethanol in gasoline. I just think you misinterpreted Peter's intent.
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
John Deere 6300 (A60462)
John Deere 6300...
2006 CHEVROLET EXPRESS 4X2 SERVICE BOX TRUCK (A59908)
2006 CHEVROLET...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A61165)
IMPORTANT PLEASE...
2019 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2019 MQ POWER...
