Wallenstein BX42 or BX62?
/ Wallenstein BX42 or BX62? #1
bpirger
I've been thinking and reading about a PTO chippers for a long while and can't count the number of Jinma vs. others threads I have read. I thought a Jinma was in my future, but I find myself leaning towards the Wallenstein at the moment.
Why? I like it when my machines work when I have time to work and I'm not yet one who links to tinker with everything mechanical to get the job done. Hence, it sounds like perhaps Jinma is not for me, and if I spend a few hundred more dollars, I can get something a bit more reliable and bulletproof.
I find myself now asking if there is a true advantage to the 6" BX62 Wallenstein chipper compared to the 4". Sure, bigger size. But will the 6" unit self feed better becuase of the increased momentum in the larger wheel, bigger knives, etc?
Any comments would be great. Any first hand experience with the self feeding Wallenstein units would be even better. And any experience directly comparing the Jinma with the feed rollers and a self feeding Wally would be ideal. :)
I have a 45 HP @ the PTO tractor, so I can handle the large BX62 without problems I believe.
Thanks!
/ Wallenstein BX42 or BX62? #2
I have the BX42, and run it with my 19 pto hp tractor. With the Hp you have available I would get the larger BX62. Not that you will be always chipping things that big, but odd shaped branches, varieties of trees (like apple) that have branches coming out at right angles, etc. will have a lot more room. Mine works fine, and is still self feeding well with about 20 hours on the knives so far. It will choke sometmes if it is fed enough leafy / stringy material, but more HP probably would help that too. I'm not sure who likes mine the best, me, or the neighbors! :D If you are chipping stuff that is pretty straight, it might not make much difference.
/ Wallenstein BX42 or BX62? #3
I have a 45 HP New Holland and thought about getting the BX62. The extra $700, and the fact that we burn anything larger than 3-4 inches, persauded me to get the BX42. After using it I am very happy with my decision. It self feeds faster than I can get the wood to feed it. It didn't bog down at all, and easily pulled limbs with wide branching angles.
/ Wallenstein BX42 or BX62? #4
I've never found myself wishing for less capacity on any attachment I own. With your horsepower, I'd get the bigger one and not look back.
Also, I have had the same experience as Chuck with regard to odd-shaped branches. Sometimes a branch with a "Y" in it will hang up unless I'm careful to put it through in just the right orientation.
/ Wallenstein BX42 or BX62? #5
I have 45hp MF; I bought the BX 42 and I am very happy with it. I would be careful putting the BX 62 on your tractor; the Wallenstein website says HP requirements for max. cap. for that model is 60-70.
/ Wallenstein BX42 or BX62? #6
Oops, showing my ignorance. Gotta agree with Merlin, I wouldn't go with less HP than recommended by the manufacturer for the BX62. I just assumed that 45 HP met the minimum. That's what I get for assuming....
/ Wallenstein BX42 or BX62? #7
You sure aren't going to harm the chippper by having less than the maximum HP it will handle. I have a 48 pto hp tractor and a BX62 and I haven't come close to stalling the tractor. I do have the hydraulic feed which probably slows down the feed rate compared to the a chipper with no hydraulics and sharp blades, so that may be a facor.
Greg
Thanks all. I was taking the kids out to their softball game yesterday and drove by a dealer with a BX42. I was surprised how small it is....it almost looks like a "toy". From the pictures, which is all I have seen to date, I was expecting a bigger footprint! It isn't about footprint, and small is better, as long as it gets the job done. Sounds like people have no complaints.
Thanks again to all!
/ Wallenstein BX42 or BX62? #9
I have the BX42 and run it on my Deere 3520. I understand what everyone is saying about the bigger machine not harming you, but I'm with Charles Billings, anything bigger than 3" is firewood to me.
If I read your question correctly you are asking about the self feed of the two machines. Although I have not used the BX62, I can tell you that the BX42 feeds nicely.
If the extra $$$ are no problem for you then perhaps the bigger machine is better. For my money the BX42 is not a toy nor does it behave that way.
Good luck on making a decision. I believe either one will make you happy.
/ Wallenstein BX42 or BX62? #10
If you even think you might get a bigger HP tractor, get the BX62.
I have 60 PTO HP, so it was my choice. I just need to find time to use it.
/ Wallenstein BX42 or BX62? #11
Oh the BX42 will get the job done. I'm kinda glad I got the smaller one, it's easier to take thru the woodlot. Here's vid of it from You Tube running on my Kitoti DK45 ... YouTube - Wallenstein BX42
/ Wallenstein BX42 or BX62? #12
I have used both the 42 and the 62, and now own the BX62. It is nearly twice as effective as the BX42. I have used the BX62 on my 62 hp tractor. The unit will take a 7-8 inch pine limb 12 feet in length, and chew through it in 10 seconds. The tractor has never bogged, or gotten into the governor. Don't waste your money on the optional hydraulic feeder. This unit pulls everything through on its own very well.
/ Wallenstein BX42 or BX62? #13
I have 4 slash piles each about 60 feet long, 30 feet wide and 15 feet high. Is it thinkable/efficient to handle it with a BX62, or should I just call in a dump semi with a hydraulic boom for $350 a load and have them load and haul it off. I could use the chips for landscaping, but I don't want to spend a week or two feeding a chipper while the sunshines.
jmf
/ Wallenstein BX42 or BX62? #14
Can you burn? Burning the scraps would be the quickest.
If this is a one time use and you can't burn, I would rent a large hydraulic feed chipper for a few days. It will be faster and more efficient than a small PTO chipper. It is surprising how fast a pile will disappear with a good chipper.
