B2920 Tight throttle
   / B2920 Tight throttle #1
iplumb
Gold Member
Mason MI.
B2920
My B2920 throttle seem to be too hard to adjust. How tight should it be? Can it be adjusted? Thanks
   / B2920 Tight throttle #2
Re: B2020 Tight throttle
They normally will wear in after a bit of use.
I'd recommend working it a bit more before adjusting. Just to work them back and forth with out the engine running twenty or thirty times often does the trick.
Thanks for the tip! I will try that:) It does have 5 hours on it now:D
   / B2920 Tight throttle #4
I don't know how your tractor throttle linkage is set up, but I lubed the cable and all moving parts on my tractor and it made it a good deal easier.
Deano
   / B2920 Tight throttle #5
I had the same problem with my B7800. I waited for two years for it to "break in" and it just didn't get any easier. I finally fixed the problem and it has been good ever since. Do a search for B7800 throttle and my post will show up and a quick description of what I did. It is not really difficult, but it is a challenge.
Good Luck
   / B2920 Tight throttle #6
Good Luck
I find your post on fixing brake light, couldn't find the throttle post. I've got the same problem with my B2710, would appreciate a pointer to your fix.
:eek:
I( have been looking also. Lots of good info but can't find the throttle post. Link please.
   / B2920 Tight throttle #8
Sorry, I can't find it either! I guess I was thinking I had written something. I will look at my machine this week and try to recall the process. But perhaps this will help - The friction is controlled by a compression nut that is hard to get to behind the sheet metal. I remember that I had to partially dismantle the "dash board" so that the sheet metal surrounding the linkage could be gotten to. The compression nut in question is located below - near the forward pedal. It is difficult to get the wrench in there, but you don't need to move the nut very much. Good Luck.
John Deere 1100 3 pt Field Cultivator (A50514)
John Deere 1100 3...
2023 AVANT 735 COMPACT WHEEL LOADER (A51242)
2023 AVANT 735...
1999 Ford F450 Dump / Plow Truck (A50514)
1999 Ford F450...
2021 New Holland C327 Compact Track Loader (A52128)
2021 New Holland...
2015 Chevrolet Equinox SUV (A50324)
2015 Chevrolet...
2018 FORD EXPEDITION (A51406)
2018 FORD...
