B2920 Tight throttle
   / B2920 Tight throttle #1
iplumb
Gold Member
Mason MI.
B2920
My B2920 throttle seem to be too hard to adjust. How tight should it be? Can it be adjusted? Thanks
   / B2920 Tight throttle #2
Re: B2020 Tight throttle
They normally will wear in after a bit of use.
I'd recommend working it a bit more before adjusting. Just to work them back and forth with out the engine running twenty or thirty times often does the trick.
Thanks for the tip! I will try that:) It does have 5 hours on it now:D
   / B2920 Tight throttle #4
I don't know how your tractor throttle linkage is set up, but I lubed the cable and all moving parts on my tractor and it made it a good deal easier.
Deano
   / B2920 Tight throttle #5
I had the same problem with my B7800. I waited for two years for it to "break in" and it just didn't get any easier. I finally fixed the problem and it has been good ever since. Do a search for B7800 throttle and my post will show up and a quick description of what I did. It is not really difficult, but it is a challenge.
Good Luck
   / B2920 Tight throttle #6
Good Luck
I find your post on fixing brake light, couldn't find the throttle post. I've got the same problem with my B2710, would appreciate a pointer to your fix.
:eek:
I( have been looking also. Lots of good info but can't find the throttle post. Link please.
   / B2920 Tight throttle #8
Sorry, I can't find it either! I guess I was thinking I had written something. I will look at my machine this week and try to recall the process. But perhaps this will help - The friction is controlled by a compression nut that is hard to get to behind the sheet metal. I remember that I had to partially dismantle the "dash board" so that the sheet metal surrounding the linkage could be gotten to. The compression nut in question is located below - near the forward pedal. It is difficult to get the wrench in there, but you don't need to move the nut very much. Good Luck.
2018 HINO 268 26FT BOX TRUCK (A51222)
2018 HINO 268 26FT...
2020 CATERPILLAR 259D3 SKID STEER (A51242)
2020 CATERPILLAR...
TC710 FINISHING MOWER (A50459)
TC710 FINISHING...
2011 International School Bus (A49461)
2011 International...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
2015 CATERPILLAR 272D2 WHEELED SKID STEER (A50458)
2015 CATERPILLAR...
