Ranch Tractor Needed: Brand? Model? HP? Please Advise
/ Ranch Tractor Needed: Brand? Model? HP? Please Advise #11
Hey All,
MulishOne You have 74 acres in the Okanogan. What is on the 44 you don't mention? The 30 ac - what kind of irrigation are you talking about? How many acres can you irrigate? Can you flood, wheelline or move pipe? Is the hay irrigated? How many cuttings? Why can the other 15 only support 5 or 6 head of cattle - is it dry? What is your hay/pasture mix? Why do you need to put in 3 ac of "green manure"? Don't you have a legume in the mix already? There is a whole lot that just don't add up here.
To my way of thinking 15 acres of hay hardly justifies anything more than a basic small square baler with an old pull type rake, an old sickle bar mower a trailer an a couple ambitious high school kids. I'm at a loss as to what to say but you could probably get by with a 8n if you had to - depending on the baler (baler with an engine on it!). You say you want to mow and rake with horses? If this is really so then just get your hay custom baled as you will spend a lot feeding draft horses.
What you really need will be determined by your basic production plan. I'd spend a lot more time figuring a production plan then think about tractors. That said a 45ish horse FWA will probably do all you need. Once again it depends on your plan.
-Ed-
/ Ranch Tractor Needed: Brand? Model? HP? Please Advise #12
Well for most of your needs I think a good utility tractor would do the job.
i would look for 70+ hp. I'm not sure how deep the lines have to be in your part of the country so they don't freeze and break but when i was watching this being done they were using a big tractor on tracks. Maybe you could hire this part out?
/ Ranch Tractor Needed: Brand? Model? HP? Please Advise #13
Personally and I'm biased, I'd go for a New Holland TN75 or TH74D with cab. Arguably the best utility tractor in the range you are in. Many owners who use them hard on this board.
Andy
/ Ranch Tractor Needed: Brand? Model? HP? Please Advise #14
Andy
Nothing wrong with being biased. :D I would also look at JD and MF. MF has some pretty nice transmission choices.
500BBL WHEELED...
2011 Ram 1500 Pickup Truck (A59230)
2011 Ram 1500...
2017 Kia Soul SUV (A59231)
2017 Kia Soul SUV...
1454 (A57192)
1454 (A57192)
1901 HOMEMADE 16FT T/A TILT TRAILER (A59906)
1901 HOMEMADE 16FT...
FENCE PANELS (A58214)
