Backhoe Replacing Tooth on BH Bucket
/ Replacing Tooth on BH Bucket #1
gregkabob
Moore, OK
NH TC45DA
I bent a tooth on my BH bucket and looking for some "TIPS" on replacing it. Getting the old one off and the new one on. The tip that is on there floats and had indentions on each side that hold it on. Do I cut it off, try to slide a chisle behind it to bend the indentions out?
Any tips from those with prior experiance on removal and installation will be appreciated.
Thanks!
/ Replacing Tooth on BH Bucket #2
Can you get a drill in there?
I'd try and drill the dimple out from each side.
start small and increase size
tom
Thanks, That's a great idea!
/ Replacing Tooth on BH Bucket #4
Thanks!
Impact tool with chisel. Less than 5 min.
UNUSED JCT HYD AUGER (A62131)
UNUSED JCT HYD...
Four (4) R207782 John Deere Wheel Weights (A63116)
Four (4) R207782...
Detroit Diesel Auxiliary Hydraulic Power Plant Generator (A61568)
Detroit Diesel...
2021 Ram ProMaster 2500 Cargo Van (A61568)
2021 Ram ProMaster...
(96) 1"X8"X10" PONDEROSA PINE BOARDS (A62131)
(96) 1"X8"X10"...
02GER CHICKET HOUSER 240' (A62131)
02GER CHICKET...
