hydraulic res size?
/ hydraulic res size? #1
saiga
meridian, idaho
2005 MF 1533
im using a 12 gpm prince pto pump to run a home made (kind of) backhoe . i have an 11 gallon reservoir. is that cutting it too close? does anyone know where to get inexpensive tanks. any thoughts welcome
/ hydraulic res size? #2
im using a 12 gpm prince pto pump to run a home made (kind of) backhoe . i have an 11 gallon reservoir. is that cutting it too close? does anyone know where to get inexpensive tanks. any thoughts .welcome
I believe your tank size is supposed to be 2 times the pumps GPM. So if your pump is 12 GPM, you need a 24 gal tank. However, if you have a small radiator with fan, you can run the return fluid through the radiator be fore dumping into tank.
I believe Surplus Hydraulics has tanks, and Baileynet.com
https://www.surpluscenter.com/home.asp
http://baileynet.com/index.php
/ hydraulic res size? #3
11 GPM reservoir for a 12 GM pump is a great match. The "ideal" setup is to match the 1:1, but you are so close it does not matter. Most consumer grade logsplitter's for instance have very small resivoirs.
/ hydraulic res size? #4
/ hydraulic res size? #5
It wasn't that long ago that the common design rule was to size the reservoir at 2:1. Recently, the rule of thumb has moved to 1:1. Most of the hydraulic fluids today contain additives that allow the 1:1 design. Just make sure your return lines are sized to slow the return flow to around 3fps.
/ hydraulic res size? #6
"24 gal tank."
All I can think of is $150 worth of oil!
/ hydraulic res size? #7
Don't you think a 1:1 is kind of illogical. The most important part of a hydraulic system is the fluid, and the temperature of the oil, very important. The turn around time for the oil in a 1:1 doesn't give time for the heat to dissipate, expunge the air, or let contaminants settle. While it is true that hydraulics in mobile hydraulic systems have shrunk, The object was to save space, and doing so, they expect the system to be a little bit more heat tolerate. I also have not seen the 1:1 ratio mentioned very much, while I have seen the others, such as 2:1 and 3:1 . I can understand that certain systems could get away with small tanks, when the system is using intermittent hydraulics. Working a pump at 100 % . I think the the 2:1 or better will give more longevity to the system.
That is my take on it, the less heat you have, gives a better operating system for the hydraulic fluid.
What ever one wants to do , he can, he is the project manager.
/ hydraulic res size? #8
Here it states 3 to 5 time the flow rate. (Cha-Ching)
http://www.hydraulicsupermarket.com/upload/db_documents_doc_10.pdf
But I'm guessing they are talking some pretty big equipment and in constant use. I've asked this question before and have decided for me 1:1 or maybe even a little less will be adequate. I figure I could always place a temp gauge on the system to keep an eye on it. How big are the reservoirs and pumps that come with the self contained backhoes like Woods? I'm also guessing that the larger the diameter of the cylinders being used the more heat generated during use. Ok the more volume of heat produced and therefore larger tank required.
Wedge
/ hydraulic res size? #9
As JJ mentioned the heat is a major concern, so if you wan't to conserve space and size of the tank you may need an oil cooler. I would definitely have a temperature guage to monitor the system. You can get by with a 1:1 system as long as the oil remains cool enough but I would prefer a 2:1 setup.
Steve
/ hydraulic res size? #11
I have a log splitter with an 11 gpm pump. The tank is about 1.5 gal. maybe 2 at most. It gets warm to the hand but you can leave your hand on it.
Of course the system pumps to tank more than it pumps to load. I think the tank size is really dependant on the work component. Rules of thumb are good for average work and always kind of a safe position. But if the application is substantially different from average you can save a lot of money or cause a lot of damage.
Did I help? It's raining out
/ hydraulic res size? #12
Dont forget that you need to be able to have the amount of oil in the tank to expand all your cylinders. Tractor dumptrailers around here, often have a PTO pump setup because the amount of oil in the tractor transmission isnt enough to pump that large 4 stage telescopic cylinder up. With a PTO pump setup, you can run a tank as large as you want.
/ hydraulic res size? #13
Heat (cooling capacity) isn't the only reason for a large tank. The oil needs an idle time in the tank for air bubbles to separate out. Particulates should be taken care of by the filter.
/ hydraulic res size? #14
I have mentioned all this before, but there are those that like a 1:1 ratio, which allows a smaller tank, and the tank and oil is less expensive. . For intermittent operation, you could get away with that. such as log splitters, and even tractors. If you have a gear tractor, you don't need much hydraulics.
My Power-Trac is all hydraulic, and with a 45 HP engine, It will allow me to pump a total of 22 GPM with in all three systems. My reservoir is 20 gal. and it gets very hot. Again, saving space. To replace the oil in my tank would cost about $280.@ #3.50 qt. Now, along with that , I have a hydraulic radiator cooler with auto fan. There are ways around things.
/ hydraulic res size? #15
Please elaborate on your "kind of" Homemade backhoe.
John Deere Gator TX4x2 (A62177)
John Deere Gator...
Lonestar Panel 24ft. Free Standing Panel with 7ft. Gate (A65640)
Lonestar Panel...
2014 GULF STREAM TRAILMASTER (A65643)
2014 GULF STREAM...
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
2018 Freightliner M2 106 20Ft. Reefer Box Truck (A64194)
2018 Freightliner...
New Idea 201 Manure Spreader (A66408)
New Idea 201...
