Rotary Cutter Bush Hog
/ Bush Hog #1
hepnerj
Broadway, Va
Kubota L4330
good morning gents.
All things being equal. IE: Price. If you had a choice between a Land Pride or King Kutter which would you choose?? Both are new and exact same price for 6 footers.
/ Bush Hog #2
I would buy the KingKutter because of KK's great website and the fact that most TSCs still carry that line. That means parts and supplies are no further away than the nearest TSC. Compare the store's open hours to the dealers for Landpride and I think you'll find that TSC wins. Being open when I need them is big on my priority list.
/ Bush Hog #3
I'd check the lowest mowing height capabilities of both, if it will matter to you. I have a KK 6 footer and it works fine, but it has a rather high blade setup. I think if the mower sidewalls drag it can mow at 5" maybe. Add an inch or two to that for practical mowing when you have the mower raised slightly above the ground and even more when it raises due to contours. For rough cutting, 6 or 7" inches is ok, but there are areas I'd like to mow at 3 or 4". Can't do it with my KK. Most other brands will mow down to 2".
/ Bush Hog #4
Are you talking about a finish mower? I've never seen a brush hog that will cut to 2" without dragging the sides.
/ Bush Hog #5
I stopped after looking up 2 brands, but both Bush Hog and Land Pride rotary cutters have minimum cutting height of 1 1/2" for their 72" models.
I think the KK cuts down to 2" on the 5 foot and under sizes.
/ Bush Hog #6
My woods Brush bull, extreme, 7 footer will cut as low as 2", the specs say 1" but it is closer to 2".
/ Bush Hog #7
Mine will cut that low as well, but the sides will drag. If I needed to cut to 2", I'd get a finish mower.
/ Bush Hog #8
LAND PRIDE!!! No Contest here! Talk about "over-built" equipment! :p
Troy
/ Bush Hog #9
There isn't a TSC within 100 miles of here that stocks enough KK parts to fill a shopping cart. And few of the stores have staff that is competent enough to order parts correctly when asked.
/ Bush Hog #10
Another vote for Land Pride. Equipment appears to be very well built.
/ Bush Hog #11
i cleaned up around my hay fields today with my 8' landpride. i vote for landpride!
/ Bush Hog #12
Troy
I would have to go with the Landpride too! I had a 4 ft model 15-48 Landpride bush hog for several years with a JD 750 and it performed very well. I did have to re-weld the yoke frame that holds the tailwheel, but I think it was broken (and welded) when I bought it (used). I eventually broke the second weld and so I finally went and ordered a new spindle with yoke for $65 and replaced it altogether. Never had a problem with the deck or gearbox though.
I think if you could see a new LP and a new KK mower side by side, the differences in welds, fit, and finish would really be obvious. One other point, I was looking for a used 5 ft bush hog myself earlier this year and I happened to check out a used 5ft KK for $450. It was actually fairly new with not too many hours on it, but it was the noisiest mower I've every heard in my life!!
/ Bush Hog #14
So, your recommendation would be LandPride?;)
I don't recall saying anything about parts stocked at TSC, but the ones here have blades and blade bolts, tailwheels, and PTO shaft parts available on Saturday afternoon and all day Sunday, plus they are open for special order parts anytime the store is open. Most tractor dealers close their doors by 5:30 pm on weekdays and are not open on Saturday afternoon or Sunday for any orders, competent or not.
/ Bush Hog #15
I re-read my post. I'm not sure why you think I misquoted you. I referred to TSC's in my area, not Texas.
TSC in this area is not viewed as a viable source for anything that has a probable need for parts support. They could be across the street and open 24/7 and if they don't have what I need it doesn't matter. All of which is irrelevant because the OP asked nothing about TSC, just KK and Landpride brands.
/ Bush Hog #16
you won't have to worry if the store is open or not with landpride, cause it's not going to break down anyway's. besides if you're bush hog breaks down, it's not like you have hay down with rain coming soon and you're baler breaks down!
/ Bush Hog
Thanks for all the replies gents.. Didn't mean to start a p!ssin contest. I choose the Landpride. Why? Because comparing the two side-by-side it appeared to me to be better built. And came with a gear box rated 10hp higher.
Thanks again
John
/ Bush Hog #18
ggod choice in my hunt for implements i have found that the land pride to be better built than most. and if you could buy for the same price it's a no brainer.
/ Bush Hog #19
I fully agree,my choice LANDPRIDE hands down.coobie
/ Bush Hog #20
I know this thread is over 30 days old but I am bored and wide awake due to medication for my back problem.
I don't know about your area, but here in central Missouri the Land Pride is over twice the price as a KK. I have been shopping for a brush mower for a month. Used ones are over priced for rusting hulks. The new KK 5' mower sells for $650 at Charlies Farm and Home. The Land Pride is twice that and a Brush Hog light to medium duty model is $985.
If you get a Land Pride for the same price as a KK either the Land Pride is stolen or they are raping people on the KK. I hope by now you have jumped all over the LP and are happily mowing brush like crazy.
2022 Forest River GANS58SA 8ft. S/A Enclosed Cargo Trailer (A64557)
2022 Forest River...
2004 Chevrolet C4500 Western Hauler Truck, VIN # 1GBE4E1294F517585 (A65563)
2004 Chevrolet...
Adams 5 Ton Fertilizer Spreader (A63689)
Adams 5 Ton...
White 18' Disk (A66408)
White 18' Disk...
2013 PETERBILT 367 MIDROOF SLEEPER (INOPERABLE) (A65643)
2013 PETERBILT 367...
2012 Allmand Bros. Maxi-Lite SHO-HD Light Tower 20KW (A63689)
2012 Allmand Bros...
