chain/binders
/ chain/binders #1
buck12
Mississippi
Kubota 5460HSTC
I recently bought my first tractor (Mahindra 2615). I bought a trailer with the tractor. I have several questions as to what to buy to tie the tractor down.
1. What are the advantages/disadvantages of lever verses ratchet binders? It seems like with the ratchet binders you could get them in a position where they cannot be tightened.
2. I think I need four binders and 5/16 chain for the tractor and a heavy strap for implement(s). Does this sound sufficient?
3. As to chain, do most of you use one long chain per binder putting the binder in the middle of the chain to take up slack or do you use a short chain at each end of the binder?
4. So far I知 thinking of buying the Harbor Freight binders. I have yet to decide where to buy the chain. Any thoughts?
Thanks for any input. I want to make sure I do this safely and as cost effective as possible. I have no experience towing a tractor but have towed boats, stock trailers, and many other items. My concern is not towing the tractor but strapping it to the trailer.
/ chain/binders #2
Have to post my opinion on Binders- I hate the ratchet binders. Bought 2 after reading others who liked them, and have tried to use them. The handle always seems to be in the wrong spot.After ratcheting for a while you figure out there is too much chain and you unwind them and try again. this week I'm buying the lever binders. Much easier to use and store.
/ chain/binders #3
I know I am in the minority here, but I use straps. I just get ones that are overrated for the job, and use them. They work for truckers, and are very handy. Just my experience.
/ chain/binders #4
You will get lots of different opinions on this. Here's my take on it.
I kept my chains and binders when I sold off my heavier trucks and equipment.
1. I've never used ratchet binders because the lever binders always worked fine for me. I use a snap-on extension (piece of pipe) to squat the tires on the tractor when I'm binding down. That way there's always tension in the chain - less chance of coming loose (the lever binder goes over centre to lock). Every one of my binders has a piece of wire attached to the handle so I can tie it in the locked position. I also wrap any excess chain around the binder. Ratchet binders might be better on tracked equipment (no tires to squat).
2. I use 4 binders - one on each corner of the tractor. I use a lighter chain and binder for each attachment (because I have them and I'm not worried about scratches). I would think a good strap would be OK for implements attached to the tractor.
3. I use one long chain and bind it anywhere along its length that I have room to do it (depends on the setup). Actually, I use only 2 longer chains and 4 binders to tie down the tractor. Each of the 2 long chains has a loose piece in the middle that effectively makes each long chain into 2 shorter chains (if you can follow that rambling explanation). I like having the long chains for other jobs.
4. I recommend G70 chains - 5/16" should be good for a CUT (I don't know the weight of your tractor), but you just might get a better deal on pre-packaged 3/8" chains with the hooks installed at some place like Home Depot). I like longer chains (15' - 20') with a grab hook on one end and a slip hook on the other, for versatility. Make sure the binders have a WLL (working load limit) that matches the chain. A 3/8" binder will work on both 3/8" and 5/16" chain.
Hope this helps.
/ chain/binders #5
I actually have both, chains and straps. I like regular binders. Either way, I use either one strap or one chain on each of the 4 corners.
Chris
/ chain/binders #6
Loading has become very tricky with all the DOT regs around. Stuff that works and has worked forever isn't legal anymore, or isn't enough anymore. Your government in action.
Anyway
I like chains, and I like lever binders. Ratchet binders work fine, I've just always used levers.
Buy at least Grade 70 chain and maybe better. You get a better working load limit (WLL) for a lot less weight. Try to buy made in america chain and binders, it will actually be the grade it's rated at.
For vehicles under 10,000lbs, you need a minimum of two chains (I'm using chains, you could use straps, it's just wording at this point) and the WLL of the chains (remember, it's the lowest of the chain, ends or binders, so they should all match) must equal at least half the weight of what you are hauling. (vehicles over 10,000lbs need a minimum of four chains)
BUT
Anything held in place by just hydraulics, not mechanically pinned must also be chained down. This includes the FEL/bucket or a backhoe if you have one.
So, what I do is use my good chains, one thru the front (where I have some loops attached to the frame, you can just use the frame, I haul all the time) and then one over the three point (mechanically attached). Then I take some wimpy chain and run it over the bucket or FEL up front (I run without a bucket a lot, I just run thru the FEL arms, if you run with a bucket, you must go over the bucket). It's not really adding WLL, it's just holding the FEL/bucket down. Oh, any loader/bucket/backhoe must be on the trailer. (can't be sitting up like in a too short dump trailer)
Shorter chain runs have less chance to get slack in them. Long runs are tough to tighten up and stay there. As herringchoker said, you have to use a persuader (cheater bar) and you have to make the tires squat a little. You're supposed to check after 25 miles or 30 minutes of driving. I always try to check right before I get on the freeway.
HTH
Oh, I buy my chains from truckntow.com. not the cheapest, but they have a real good selction and verbage explaining what each one does. They also offer a bunch of made in america chain/binders.
If you use straps instead of chain, you have to use something to protect the edge from getting chafed. (commonly over the bucket or any sharp edge).
/ chain/binders #7
I used to use nothing but lever binders, but this year I switched to all ratchets. They are just much more secure. Harbor Freight binders are of remarkably good quality for the price, although I did get one defective one (bad casting) that had to be exchanged.
Rusty
/ chain/binders #8
I've been using the Harbor Freight ratchet binders for years with no problems. Compared to the lever style, the only disadvantage to the ratchet binders that I can think of is, you have to keep them lubricated and stored out of the elements when not in use.
Joe
/ chain/binders
Thanks for the replies. If straps are ok I would rather use straps. My tractor and FEL weigh about 3300 lbs. Straps seem easier to work with. For those of you that use straps what should I consider other than the working load limit?
/ chain/binders #10
I use the 10k 3300 WLL straps for small stuff. They will loosen up, so plan for it. As others said make the runs short, avoid chaffing, come off the machine and straight down as possible, don't go for the corners of the trailer. Last thing is tie up the loose strap ends - don't want one to unroll & get stepped on by the trailer wheels running down the road.
One thing you might consider is replacements as they get wet, dirty, oily, greasy and frayed anyway. Chain is more durable, ratchets safer than snap binders.
/ chain/binders #11
Well, like I said, you can't go over anything sharp without something to protect it.
You can't leave them out in the sun
You can't leave them out in the rain
They get damaged pretty easily
They will loosen when they get wet.
Chains can lie around for years and are still fine.
IMHO straps are good for stuff, for equipment, chains.
/ chain/binders #12
I really like the ratchet binders much more than the lever binders I used - have used the ratchet ones for years with no issues. The infinite adjustability I think is nice. They also can be used in other situations like a small come-a-long. We have used them with chains to pull beams together etc.
Ken
/ chain/binders #13
This is an important point. For the OP, find out what your state, and/or other states that you will haul your tractor in, require.
Some time back, I checked directly with California Highway Patrol, to make sure how to properly secure my little Kubota. I made sure they understood it weighed only about 2500lbs. They indicated, that in Calif, the requirement is a restraint on all four corners. They did not care if it was lever vs ratchet binder, or strap vs chain, as long as it was rated high enough for the load.
Other members here, long haul truckers, in other threads indicated that while in one state only two chains are required, you could in fact get a ticket for hualing that way when you crossed the Calif state line.
I personally, gave up on straps. They got weathered, got nicked. Now I only use them for securing hay or boxes on my trailer. Otherwise, I use chain and lever binders. Lever binders, mostly because that was what a store here had at the time, and I had used them in the past while helping others out.
Anyway I like chains,
/ chain/binders #14
Not to be dissagreeable, but I have never had a strap loosen when wet. I use them a lot, and truckers use them all the time to secure sensitive loads. Of course you can't go over anything sharp, and leaving them in the sun is not good for them at all. And I have never damaged one, and trust me, I haul things all the time. I like the regular hooks on the ends. The snap hooks make sure you won't lose them, but can be a real pain. The flat hooks just don't do me any good. And like was said, tie up those loose ends. Running over one can be a disaster.
/ chain/binders #15
I see them all the time on big rigs too. On static loads, ie pallets or boxes. On loads that can roll, I always see chain/binders.
Wonder why...???
/ chain/binders #16
For my short hauls I use straps, stored out of the elements and repalced regularly. It is imperative that you pay careful attention to chaffing. Even the heavy duty staps can be cut with a butter knife when they are tight
As far as just loosening up on their own I have never expierenced it. I will also add if I where going on a long interstate trip the chains and rachet binders would be used.. Just my 02 cents..
/ chain/binders
After some reading and shopping, I think chain and binders are not only better but likely cheaper in the long run because the chains will last where as straps will have to be replaced. Now to my next question. It seems Lowes has a good deal on 20' of 5/16" grade 70 chain with hooks. Two of these cut in half will give me four 10' chains which should be more than enough chain according to my measurements. The question is what is the best/easiest method to cut the chain? Also, it seems all the binders I've seen are made in China. Does anyone have experience with the China made Harbor Freight binders verses more expensive China made binders from other sources?
/ chain/binders #18
I have had good luck with HF binders. As for cutting the chain, grade 70 is tough. Lowes should be able to cut it since they cut bulk chain to length. If no I would recommend a cut off wheel for a 4.5" angle grinder. You can get the wheels at HF for a few bucks each and they will cut it like butter as long as you have a vise to chuck it in.
Chris
/ chain/binders #19
Yes, the cut-off wheel (which also can be purchased at Lowe's or Harbor Freight) is really the best way to cut grade 70 chain safely. Don't forget the extra Grade 70 hooks while you are there.
You can cut the chain with big bolt cutters or hydraulic cutters but you might damage the cutter or throw a big chip of metal. Not worth it, go with the cut-off wheel.
/ chain/binders
I do have a 4.5" grinder but had not thought about it. Thanks
2021 Ford Explorer SUV (A66738)
2021 Ford Explorer...
2005 Oskkosh MK48A1 8x8 Articulating Tactical Truck w/ MK14 20ft. Flatbed Container Hauling Trailer (A66736)
2005 Oskkosh...
John Deere 2840 Tractor (A64047)
John Deere 2840...
PRESSURE WASHER (INOPERABLE) (A68842)
PRESSURE WASHER...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
2016 Mobility Ventures Van (A66738)
2016 Mobility...
