modifiying trailer for dump action?
/ modifiying trailer for dump action? #1
KsM715
Hi all. Ive lurked here off and on for a few years, Lots of great info.
Ive searched for a few hours now and cant find the answers Im looking for. Im getting a m105a2 military surplus trailer in a few weeks and need to modifiy it into a dump trailer. The questions I have are: 1. Ive seen to different ways of mounting the cylinder, one way with the cylinder from the frame to the box and one with the cylinder mounted to a sissor (spelling?) type frame inbetween the frame and box. Its not a big trailer and I dont intend on loading it heaping over with dirt or gravel, Is mounting the cylinder from the frame to the box strong enough? Is there a way to figure out how far forward or back the cylinder can be mounted?
The pics are of the trailer like I want to build and of the trailer Ill be using.
/ modifiying trailer for dump action? #2
I would say a lot depends on how the trailer is assembled. It is far better to design a dump trailer from the beginning as such. A dump trailer is a dump box on a strong trailer frame. Most trailers not designed to dump, incorporate the box as part of the frame to save weight and materials. Converting one of these to dump can require a LOT of work and re-design of the frame and box to accomplish this.
The scisors framework lift design allows you to use a shorter stroke cylinder, and less hydraulic fluid, so a smaller resovoir is required. The scisors framework also more precisely controls the travel of the box and the forces applied to the cylinder. Fully extended cylinders can be damaged by uncontrolled side forces. The trailers that use a single cylinder and no scisors framework require a very long cylinder. Any flex in the box from uneven loading can put large side loads on this cylinder, so a very stiff box and pivot point are needed to keep from damaging the cylinder.
When converting something to serve another purpose, I always find it best to either draw the original into my CAD program, or build an Exact scale model. The CAD program is of course much less work, and easier to modify. You have to know where you are, before you can decide where you need to go... Once I have the original mocked up, Then I can experiment with different ways to achieve my end result, and get my brain around all the variables involved with the project.
Good luck with your project.
/ modifiying trailer for dump action? #3
Sometimes the converting is more expensive and agravating than starting from scratch. Good luck with your project. I have looked at enough of them to know how I want it constructed so it will provide years of trouble free service.
Some of these conversions end up being money savers which relate to goobered up attempts to look like an original. Make a plan and don't cut corners in strength and safety matters. Remember... we like progress pictures !
/ modifiying trailer for dump action? #5
Here is my dump trailer project:
CLICK HERE
I agree it's much easier to design and build a dump trailer from scratch. Although modifying an existing trailer to function as a dump trailer can be equally rewarding.
Personally, I would go with a straight hydraulic cylinder lift mechanism vs a scissor lift due to simplicity. "Will mounting the cylinder from the frame to the box be strong enough?" I seriously doubt it. The cylinder mounting points will need to be beefed up where it will withstand the maximum force available from the cylinder for a safety / failure factor of at least 2-3X the force of the cylinder. Additionally, the cargo box will most likely need to be stiffened up so as to support the weight of the load between the rear pivot hinges and where it gets lifted by the hydraulic cylinder (so it doesn't fold in half when being lifted).
"Is there a way to figure out cylinder placement?" -It depends on the weight being lifted, total angle of lift, bore and stroke of the cylinder, vs the available hydraulic pressure, unless your a genius at trigonometry and calculating mechanical force, it's basically more or less trial and error. First determine what angle dump you want, (45* is a good rule of thumb for a dump trailer). Then find out how much space you have to work with to determine the retracted length, stroke and bore of the cylinder. Hint - over kill is the rule of thumb here. The lower and more forward the cylinder is away from the rear pivot hinges will give the best mechanical advantage. I used two 2.5" dia 16" stroke cylinders - one on each side, or it could have been done with one 4" cylinder in the center. I opted for two cylinders to spread the load and forces over a wider area.
If you need help determining exact cylinder placement, bore and stroke....Post some pics and dimensions when you get your surplus trailer taken completely apart, then we can all take a look at it for a better assessment.
Larry
/ modifiying trailer for dump action? #6
The trailer in the picture has a very high ground clearance, which means that you can place the cylinder allmost vertical: Thats most beneficial, as it will give the most lifting force with the smallest cylinder.
Most i've seen in American dumptrucks are scissor lift, though in Europe, telescopic cylinders are much more popular: they are suspended on a pivot mounted on the rod side of the cylinder, and with 3 or 4 stages, they can be positioned upright, in the middle under the bed and still tip 70 degrees.
Over here, there are lots of telescopic cylinders available at stores, mostly made in India.
Whatever you decide, remember that horizontal placement of the cylinder requires a big cylinder and beefy hinges, and gives only a limited lift force where it is needed most: when the bed is horizontal. Then when it tips up, the cylinder gets more effective when the dirt is already starting to roll out, which means you loose a lot of speed to pump oil into that big cylinder.
The more vertical you place it, the more efficient the overall design, both mechanically and hydraulic.
/ modifiying trailer for dump action? #7
I'm not a genius, i did some dumptrailers in my previous occupation, but just a little fiddling with Autocad and 2nd year high school physics is enough to figure this out.. Autocad (or the chinese copy of it, www.zwcad.org) is a great substitute for everyone who didnt care about sinus and cosinus back at school ;)
/ modifiying trailer for dump action? #8
RonMar did a greeat job of hitting most of the highlights.
I also agree that a scissors type lift assembly is the way to go.
Almost all larger dump trucks use a straight compound cylinder which is incorporated into the design of the box as well as the frame.
Check out an older grain truck or an old farm wagon, they both used the scissors type lift assembly. I have seen a number of people try to use them as a light duty dump truck with poor results as they were never designed for gravel or dirt. They should work great with the size of a dump box as you have pictured.
If you hunt around, you might be able to find a scissors assembly for cheap at a farm auction if you aren't in too much of a hurry. I believe that the Surplus Center also sells them in case you want to purchase a new one of get an idea to build one from scratch.
Also keep in mind where the hinge point is located. I wouldn't put it all the way at the back of the box, but putting it too far forward can be even more of an issue as the load is being dumped with the box and load raised up. While there is not an exact science, I think around 5% of the box should overhang. A typical grain truck can have 30% or more; however, grain typically flow very easily and not get hung up.
Wow thanks for all the responses and insight. Im not in any hurry and usually tend to take awhile to actually doing and of my projects. (lots of time for research and parts searching) I am going to brace the underside of the box somehow. There is tons of ground clearance under the trailer but I dont want to mount the cylinder vertical, I dont think I need that much power to worry about that and i want to keep the trailer looking almost stock. I will take pics when I get around to doing it.
/ modifiying trailer for dump action? #10
Whatever you decide, remember that horizontal placement of the cylinder requires a big cylinder and beefy hinges....
I was contradicting myself quite a bit here: Off course i meant that a HORIZONTAL placement of the cylinder is quite inefficient.
....but I dont want to mount the cylinder vertical, I dont think I need that much power to worry about that...
Actually the forces that occur on the box and hinges, when trying to punch out the dump box from a near dead angle, is what worries me :(
I agree with, if a standard scissor lift for dump trailers is available from surplus center at a decent price, its not worth your time and effort to fiddle with it yourself.
One more thing to consider: We have an old dump trailer, which is basically a 3 sided dump body on an ages old Bedford chassis, with the frame rails bent together into a V shaped towbar. The problem with this dump is that i allways get stuck with it with a dumped bed: The axle is too much in the middle of the bed. When dumping, the center of gravity shifts behind the axle, which means that the trailer will try to lift the tractor from the drawbar.
few weeks ago a load of garden mulch mixed with brush and branches, plugged up behind the tailgate, which caused my 3011 to be lifted off the ground... :( :( that was quite a scary situation.
I had to pull it forward with the 5245 before the plug released and the weight was releasing off the rear end of the dump body.
Believe me you dont want that to happen, it gives such a funny feeling in your belly when you realise that the tractor rear wheels are spinning freely, being lifted a foot off the ground... :D
/ modifiying trailer for dump action? #11
This is an ongoing project of mine.
/ modifiying trailer for dump action? #12
This is an ongoing project of mine. If intersted I can send measurments of mine.
/ modifiying trailer for dump action? #13
I built one about 20 years ago using a "Camper Jack" to raise the trailer... It's work find ever since... the only shortcoming is it is pump action and not that quick.
The trailer is home-made...even the hitch and the swing boom... I used to have lots of time and little money... now it's no time with a little more money.
The Jack is mounted on the trailer draw-bar and the trailer pivots on the axle... one of the beauties of having a single axle trailer.
I also have a tilt bed car hauler that works the same way without the jack.
On the plus side... the dumping mechanism and installing it cost less that $100 plus my time...
I'll try to take a picture.
/ modifiying trailer for dump action? #14
I work at camp robinson in arkansas. we, the guys at work, had the same idea when they post on auction. we talk ag morning at break. before i was full time i worked at a plastic plant. the Mech Eng's always had to do all kinds of math. i am an electrical Eng. i found just going to a pneudralic or motion indstrual supply the inside sales guys wil be able to help you. yes you'll need to make a frame for you trailer.
/ modifiying trailer for dump action? #15
Here is my dilemna- my scissor lift trailer will dump its 5 ton load normally with little trouble. However a few times the loader operator has dropped the load piled a little toward the front, or I'm nose down on a hill where I want to dump. The sizing of the cylinder and pump is right on the hairy (cheaped out?) edge of lifting when everything is perfect. So when front heavy it can't get the bed to rise without a little help, I usually use a Hi-Lift jack on a corner to get it going. Once its up 2 or 3 inches it takes off and goes fine.
My thought is if I cut the trailer end cylinder mount hinge off and reweld/remake it a few inches lower it should give it more off the line lift at the expense of a couple of degrees of ultimate dump angle.
Any mechanical engineers out there that can confirm my plan?;)
Can't use a bigger cylinder because there isn't room. I have considered installing a small "booster" cylinder vertically at the front of the dump bed to push that extra few inches to get it going. Cost is a minor issue here and all the extra plumbing into the hydraulic pump.
Below is a pic of a trailer like mine- the large "hinge" circled at the lower front is what I'm proposing to lower.
/ modifiying trailer for dump action? #16
Skyco,
given the geometry of your scissor lift, placing it lower so it doesnt reach as much of a dead end when lowered, would certainly make it easier for your hydraulic pump to punch out the bed from a dead start.
Just use a tape measure to measure the total expansion of the scissor lift, deduct the inches you want to lower the attachment hinge, then lower the bed to that length, to see if you can live with the dump angle, before deciding to cut up a perfectly good dumptrailer... ;)
/ modifiying trailer for dump action? #17
Skyco,, How many pounds of life do you think your appling with the high lift jack??? The reason I ask is a few years back I built a show truck with a air powered lift like yours.. but after putting the finishing touches on the truck it wouldn't lift the finished bed,,, I put a come along on my dear scales and lifted it untill the bed would move on it's own,,, about 200lbs is what it took..
The truck was done,,,frame was all clear coated and I couldn't move my pivot point with out a lot of redoing,,,Sooo to make a long story short I installed a set of struts to help with the first inch or so,,,Struts might not work for you but maybe some short springs near the front between the frames...
Just a thought,,,
/ modifiying trailer for dump action? #18
Skyco,
You can confirm it yourself by making a 2D scale model of each component's profile out of index card stock. Mark your pivot points with a dot then assemble the linkage by pinning all the attachment points together with common pins. A working scale model of the cylinder, since it telescopes as well, will take a little more work on your part. You can then articulate the linkage and adjust attachment points, etc.
John
/ modifiying trailer for dump action? #19
Me and a buddy of mine had to up size the lifting mechanism in our 14k dump trailer, it was a undersized straight cylinder, we put a 18k Colt scissor lift in it. Lifting problem solved.
You can up size the whole scissor mechanism, It may cost a lot more than you may want to spend but it will lift anything you put into it.
Ford 3910 Tractor w/ Great Bend Loader (A64047)
Ford 3910 Tractor...
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
BUSHHOG 286 - 6' ROTARY MOWER (A64277)
BUSHHOG 286 - 6'...
2012 DODGE 2500 RAM (A65643)
2012 DODGE 2500...
2009 Vicon 2400 9ft. 3 Point Disc Mower (A65640)
2009 Vicon 2400...
PAN (A62613)
PAN (A62613)
