Tazewell Visit Suggestions
/ Tazewell Visit Suggestions #21
/ Tazewell Visit Suggestions #26
I'm talking about a Showroom like inside a tractor dealer.
What I actually what to see is the 1850 on the 45 Degree Rack that ponytug pointed out on his Tazewell Trip report ;)
They won't allow you to take pictures inside the showroom for some strange reason...
Several of us have tried...
Ooh! What are they going to do?! Kick out paying customers?! I'm just kidding.
I would really like to see that 1850 though, so I could also get the idea of how step 45 degrees is.
/ Tazewell Visit Suggestions #28
Toolcat.
Here is a Google Earth placemark. If you are a Google Earth fan, which I am rabid about, turn on Street View... Will show you what to look for
I cannot open this, Carl. Something is wrong with this, I downloaded it, double clicked it, and the same download icon came up. Oh well.
BTW Carl (and everone else) you can just call me Willie.
/ Tazewell Visit Suggestions #30
Willie
It works for me but I have a mac so everything always works ;-). You have google earth and the latest version, right?
Anyway, just look up Tazwell, then go north out of town... Right at the 19 and the 1302/61
/ Tazewell Visit Suggestions #32
An 1845 is only $1K cheaper that the 1850. The specs for lift are the same. Is fuel consumption the main reason people go with the 1845? One can always run the 1850 with singles if you need the narrower width.
Ken
Ken
Well Ken, When you think about that you think it's not much more to go with the 1850 but once you start adding up attachments it gets up there. For one the 90" Rough Cut Mower is $4,900 (with the Finish Cut spindles and Blades). A 90" Mower would be a bit big for us but we'd take it. Plus the 1850's 65 hp, 20 More hp than the 1845. And aren't the Loader arms basically for a 30hp tractor? I don't like the sound of that.
I don't know many people buy the 1845. I think it's the size of the machine.
Most people bought them with Single Tires before the 1445 came out.
/ Tazewell Visit Suggestions #34
$1000 and 20HP? I guess fuel costs could be a factor, but I am not sure how much of a real difference you are going to see...
You will be able to run the 1850 at less RPM for the same results.
I would want the added HP. Oh, and the wider mower, Man you will love it. My neigbor has a little BX with a 4 foot brush hog. Always borrowing the 1850 cause nothing cuts like 8 feet...
/ Tazewell Visit Suggestions #35
The extra cost in the mower is well worth it for the extra width. I do have some narrow trails in the woods that i had to widen for it but then most of that would have had to been done for the dual wheels any ways.
Ken
Ken
I hadn't really thought about this. The JD 709 Bush Hog we have has a 7 foot Cutting width and we love it. The 65hp Compared to the 55hp in our JD 5310 would be nice :) I'm just worried about the whole scalping issue I heard with the 72" but I don't see why the 72" or the 90" mower wouldn't cut grass lawns any different than a regular mower deck (when the 90" has the Finish mower blades and spindles on it) Another that kind of bothers me is that the 1850 is 65hp with basically the Lift Arms of a 30hp tractor (1430). Only 1200lb lift rating on a 65hp tractor? :confused: That seems weird to me.
/ Tazewell Visit Suggestions #37
I wish it had greater lift capacity since it is an all around tractor for me. The extra HP is going mainly to the PTO to drive the larger mowers.
Ken
/ Tazewell Visit Suggestions #38
There is nothing weird about it. It is sold as a slope mower, not as an all around machine. It you need an all around machine, it is probably not the best option.
/ Tazewell Visit Suggestions #40
Snowridge hit it right, the 1850 is a mower first, and a utility tractor second. But, when I started comparing specs, The lift capabilities were a match for a 35hp tractor (not lift height, which is a bummer). And yes, I personally feel the lift arms could be stronger. and longer.
But I have pushed my tractor hard. and the only weak link has been the rollover. I attribute this to the 65HP pushing, but it could be also attributed to the traction you get with dualies. The arms themselves have had no issue. That may change as I am going to upgrade the rollover this summer, but that is TBD. If I break the arms, there is a great machineshop at the end of the street and I may just upgrade the PT front end..
Terry has warned me against this as he says the 1850 has thinner steel, rear weight than the 1445/1460.
But the 65HP at the wheels, it really does make a difference.
2010 FORD F-150 XL CREW CAB TRUCK (A62130)
2010 FORD F-150 XL...
2000 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2000 Bobcat 863...
2017 Bobcat T770 Compact Track Loader (A63118)
2017 Bobcat T770...
BUNDLE OF APRROX (20) 3'X30' METAL SHEETS (A62131)
BUNDLE OF APRROX...
24in pin on tooth excavator bucket (A61307)
24in pin on tooth...
UNUSED JCT 84" SNOW PUSHER (A62131)
UNUSED JCT 84"...
