MtnViewRanch
Elite Member, Advertiser
- Joined
- Mar 19, 2005
- Messages
- 10,697
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
The problem with virtually all QA schemes is the extension of the 3ph arms and consequent increase of implement leverage on the tractor. This affects handling and causes more stress on tractor parts. We had an 1100# flail on an L3450 rated for 2000 pounds. The implement was on a Pats QC system. My wife hit a moderate bump with the implement up and it crashed to the ground. The internal arm that drives the rocker shaft broke. The price of convenience?
larry
Larry, can you truly say that if the Pats QA was not on there, that it would not have broken anyway? Surely the added 3" in length does not get the implement out to max weight? What if you had had 2000lbs right at the pins and did the same thing? Would it have broken then? All things to ponder, I think that there might have been a flaw in the internal arm and it was going to break sometime anyway or by chance did your wife hit that moderate bump a little faster than she had thought.
I have no idea and for some of these reasons and for the fact that I just don't need one, I have no quick change for my 3pt.
