3-Point Hitch Telescpoing 3 point arms.
/ Telescpoing 3 point arms. #1
fjtoyman
Anyone have a sourse for telescoping 3 point arms for a 4720? I called my local dealer and they said they were not an option for that model. Mine is an 07.
THX
/ Telescpoing 3 point arms. #2
My dealer installed mine and they were the best money I ever spent on a tractor part. I have a 3520 but I would think they would have them for the 4000.
/ Telescpoing 3 point arms. #4
My 4320 came new from the dealer with telescoping 3 point arms. Great feature to have.
/ Telescpoing 3 point arms. #5
THX
He is wrong - I had them on my 4720 and I added them to my current 4520.
D.
/ Telescpoing 3 point arms. #6
I have them on my 4520 also you can order them from any normal Deere dealer. The code for Telescopic draft links is LVB25309 $332.00
Steve
/ Telescpoing 3 point arms. #7
Yep, what he said.....
Just got mine 2 weeks ago, and I like 'em!!
-Jer.
/ Telescpoing 3 point arms. #8
FYI, if you plan on using a quick hitch in the future, you don't need the telescopic link arms. Quick hitch is cheaper than buying new link arms.
/ Telescpoing 3 point arms. #9
If you have telescopic link arms and the I Match quick hitch you have the best of both worlds. Easy to hitch to old and new implements, not everything is IMatch.
Steve
/ Telescpoing 3 point arms. #10
The telescoping arms are a better, more universal, choice for all your implements. Found this out the hard way..... The quick hitch is easier when your implement is made to ASAE standards, but only around 1/2 are.....
-Jer.
/ Telescpoing 3 point arms. #11
-Jer.
I totally agree - no more quick hitches for me. I went to telescoping draft links on both of my tractors.
D.
/ Telescpoing 3 point arms. #12
If your equipment is compatible, I will take a quick hitch anytime over telescopic links. Takes seconds to hook up with a quick hitch. The bigger the tractor/machinery, the more valuable a quick hitch is. I have 6 tractors and 6 quick hitches with hydraulic top links. Cat III to Cat I. 245hp to 44 hp. Many of my tractors have telescopic links. Never need to use them with a quick hitch.
With a quick hitch, it doesn't matter if your not quite square to the attachment or on level ground.
/ Telescpoing 3 point arms. #13
Agreed, provided you're OK doing some handy fab work to make ALL of your implements compatible. I'd love to back up, lift up, and go on everything, but it just doesn't seem to have worked out that way.....
-Jer.
/ Telescpoing 3 point arms. #14
You know, Landpride makes a quick hitch that is skidsteer compatibal to use and move your implements. The cool thing is that it is like pallet forks, you can ajust them to fit any implement from cat0 to cat3. If only I had one and the tractor dealers made one similar for the 3 point.
