3-Point Hitch Telescpoing 3 point arms.
   / Telescpoing 3 point arms. #11
The telescoping arms are a better, more universal, choice for all your implements. Found this out the hard way..... The quick hitch is easier when your implement is made to ASAE standards, but only around 1/2 are.....
-Jer.
I totally agree - no more quick hitches for me. I went to telescoping draft links on both of my tractors.
D.
   / Telescpoing 3 point arms. #12
If your equipment is compatible, I will take a quick hitch anytime over telescopic links. Takes seconds to hook up with a quick hitch. The bigger the tractor/machinery, the more valuable a quick hitch is. I have 6 tractors and 6 quick hitches with hydraulic top links. Cat III to Cat I. 245hp to 44 hp. Many of my tractors have telescopic links. Never need to use them with a quick hitch.
With a quick hitch, it doesn't matter if your not quite square to the attachment or on level ground.
   / Telescpoing 3 point arms. #13
Agreed, provided you're OK doing some handy fab work to make ALL of your implements compatible. I'd love to back up, lift up, and go on everything, but it just doesn't seem to have worked out that way.....
-Jer.
   / Telescpoing 3 point arms. #14
You know, Landpride makes a quick hitch that is skidsteer compatibal to use and move your implements. The cool thing is that it is like pallet forks, you can ajust them to fit any implement from cat0 to cat3. If only I had one and the tractor dealers made one similar for the 3 point.
Push Mower (A55973)
Push Mower (A55973)
2002 X-L100HDG 40ft 50 Ton Tri-Axle RGN Lowboy Flatbed Equipment Trailer (A55852)
2002 X-L100HDG...
2014 Toyota Corolla Sedan (A55853)
2014 Toyota...
2003 Big Tex 10PI...
2018 Dodge Charger Sedan (A55853)
2018 Dodge Charger...
2011 Ford Escape SUV (A55853)
2011 Ford Escape...
