Quality Replacement Garden Hose Ends
/ Quality Replacement Garden Hose Ends #1
DocHeb
Michigan
New Holland TC40D Supersteer
I bought some high-quality 3/4" by 100 foot garden hoses three years ago. They weren't cheap, but I thought I was paying extra for quality. Now two of them have had their brass ends crack and are unusable. I have never been happy with any replacement hose ends I have used in the past. They are either cheap plastic, don't fit, or the worst - involve worm gear hose clamps. Any suggestions for the ultimate replacement hose ends?
My optimal solution would be a crimped-on end similiar to OEM, but my local hose shop just stared blankly when I asked.
/ Quality Replacement Garden Hose Ends #2
those 'cheap' plastic ends hold up very well...assuming you don't drive over them.
/ Quality Replacement Garden Hose Ends #3
Ten or twelve years ago, I found some all brass screw together ends and splices that were great. And a month or so ago, I searched everywhere I could think of, eventually gave up, and bought a plastic one.:( I guess our garden hoses are supposed to be disposable like so many other products in these times.
/ Quality Replacement Garden Hose Ends #4
/ Quality Replacement Garden Hose Ends #5
Jason, I'm afraid that's the kind I was talking about. The two screw type; better than nothing, but not much better.
/ Quality Replacement Garden Hose Ends #7
Reddog, I'm not sure if it's the same brand, but that's what I used 10 or 12 years ago that I really liked. They made the same style for repairing or splicing hoses together. It seems someone left my nice new hose laying by the garden, the grass grew up around it, and it got run over by the lawnmower. And to make matters worse, I couldn't even blame it on my wife.;)
I've used that type in the past on some 5/8" hose, but the difference between 5/8" and 3/4" is such they don't match. I would give thay style if I could find some for 3/4" hose.
/ Quality Replacement Garden Hose Ends #9
Yeah, i dont like using the factory "screw type" clamp either. I was suggesting that he use the threaded brass hose coupler part, but instead of the zinc 2-piece clamp, use the Oetiker ear style clamp pictured. I keep a selection of various sizes on hand and rarely use a worm screw clamp anymore. They give a great connection in a compact package, with nothing to scratch or get hung up on anything, like the 2 piece or worm type clamps.
/ Quality Replacement Garden Hose Ends #10
Perhaps something like this. I prefer to put a wrench on it, rather than use knurled fittings - just my preference.
Farmtek sells them in male/female pairs in several hose diameters:
ValuTek Brass Hose Fittings - FarmTek
I hope this helps,
- Marty
I hope this helps, - Marty.
Thanks, I'll give those a try - I like the specific sizing and the hex facings.
/ Quality Replacement Garden Hose Ends #12
Anyone know of a source for a good quality sprayer? One that doesn't break the first time you drop it. Those cheap, made in China ones aren't so cheap if you have to buy them in bulk.
/ Quality Replacement Garden Hose Ends #13
Bug sprayer?
I have a Hudson Bugweiser in stainless thats been great. Nice brass wands. Totally re-buildable (for under $15). Only time i had to rebuild was after i left pesticide in it over the winter.
Well, the ends that I ordered from FarmTek came today. They are quite impressive, hefty chunks of machined brass - probable about 10 oz a set (Male & Female). However, they have VERY tight tolerances for the OD/ID and wall thickness of the hose so they won't fit my hose. Since I already have the Farmtek fittings I will probably buy some of their hose that the fittings were made for.
I did find some Ferulles and Garden Hose Barbs at FittingsandAdapters.com. I will take a printout of the web page to my local hydraulic hose shop to see if they would try swagging these to my hose. However, it would be something out of their norm and it is hard to find people willing to try something different.
/ Quality Replacement Garden Hose Ends #15
Chris -
Wow, that was fast delivery. I'm sorry the fittings didn't work out for you.
- Marty
Chris -
- Marty
No need to feel sorry - I'll probably switch over gradually to the Farmtek hose if the first batch I buy works out well. I like the concept of removable/reusable hose ends so that if I damage one section of hose I can easily and neatly repair it.
/ Quality Replacement Garden Hose Ends #19
The Craftsman black rubber hose at sears is very good quality. It is guaranteed for life and is made in USA!
/ Quality Replacement Garden Hose Ends #20
Just take a utility knife and slightly reduce to outside diameter of your hose until the ends fit. I've done it and it works great.
Greg
UNUSED JCT 72" HYD BRUSH CUTTER (A62131)
UNUSED JCT 72" HYD...
2016 CHEVROLVET SILVERADO 2500 TRUCK (A62130)
2016 CHEVROLVET...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
2016 Jeep Compass 4X4 SUV (A56859)
2016 Jeep Compass...
UNUSED ATS 4'X300' GRASS PROOF CLOTH (A62131)
UNUSED ATS 4'X300'...
UNKNOWN 500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
