BX-24 RPM Question
   / BX-24 RPM Question #1
HVACDIESEL
What RPM'S DO you cruise around at? Use the FEL? Use the rear loader?When I bought my machine the salesman said 1/2 to 3/4.
   / BX-24 RPM Question #2
Whatever's comfortable. Generally mow wide open. General cruise around and carry stuff, 2,000 rpm. BH up to wide open depending on the job and how big the rush. Higher revs use more fuel and make more noise. The tractor really won't care and you won't hurt it.
   / BX-24 RPM Question #3
I've found if I want to work fast yet conserve fuel I run max at 2800 rpm unless mowing. Then I run it at 3100 rpm. When plowing snow or grading the driveway I'm usually going slow anyway so I run down near 2400 or less. When moveing lots of dirt in tight or steep areas I use lowest rpm I can and raise it up as necessary for better lifting.
   / BX-24 RPM Question #4
Oddly, I've never had mine up to 3000. When I'm just toting stuff around with the loader or traveling otherwise, I'm at about 2400. If I'm using the backhoe, I have it at about 2800, maybe 2850 at the most. I'm probably just paranoid, but going above that just sounds like it's too high. But, if I get some PTO-powered implement, I'll run it at the RPM needed for the right PTO speed, which is above 3000, I believe.
   / BX-24 RPM Question #5
Man you guys are good. I typically use mine at about 2100rpm. When I use the backhoe I really have to slow things down so I don't over compensate my motions. So again, I usually do most of my work at 2100rpm. Only when the limits of the machine are attained do I bump up the rpm for more foce but only momentarily. If I am cruising on my driveway I will bump it up to 3000ish.
My govenor will allow it to rev up to 3500 or so, but I don't like to run it that fast.
I suppose as I get more comfortable using my machine (especially the BH) I may up my RPM's but until then, I am comfortable with the lower speeds.
   / BX-24 RPM Question #6
I have a BX24. I just spoke with the Kubota regional service rep and he stated that Kubota prefers that while in use (esp. when using the loader or backhoe) that the engine is run at full throttle. He also added that although you may be able to operate the loader at lower rpm's, it's actually putting a drain on the engine to do so.
   / BX-24 RPM Question #7
I agree 100%..said that for years and JD said that to me in the early 90's...
Sad part is the TQ drops off I think after like 3K rpms.
   / BX-24 RPM Question #8
All machinery should be ran WFO wide *&c*ing Open, as thats where the machine is cools its self better and is made to run. This is the reason lots newer ag equipment (combines & spray coops) will only run wide open when being used.
The quickest way to burn up a air cooled motor is to run it @ 1/2 throttle.
   / BX-24 RPM Question #9
But the BX is not air cooled...But I agree.
   / BX-24 RPM Question #10
Normally with mowers I would agree with WOT(Wide Open Throttle) 'cause they're air cooled and the fans built into them cool better at that speed. However, if you read the BX24's manual, it states to run the machines rpm only as high as necessary for digging to prolong the life of the tractor, conserve fuel, and decrease noise. I've run mine at low rpm's for a day in 100 degree weather and never ever seen the temperature gauge go higher than half way. The cooling system is more than capable of cooling this machine at any rpm. From what I've just read, I doubt the regional service rep ever read the BX's owners manual.
Hyster H155XL Forklift (A48837)
Hyster H155XL...
Danuser Digger F-8 (A51039)
Danuser Digger F-8...
2016 CAT 289D SKIDSTEER (A50854)
2016 CAT 289D...
3014 (A50657)
3014 (A50657)
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
