Quick trailer question
   / Quick trailer question #1
HVACDIESEL
Cant find any info through search.Is there any advantage to having a dovetail on a trailer for moving my BX-24?
THANKS
   / Quick trailer question #2
I believe a dovetail trailer might make it easier to load if you have a mid mount mower deck attached. Having a dovetail gives you two smaller cresting angles for low hanging mid mount implements where a flat trailer with ramps has one greater angle to pass over that the mower may hang up on. I use a tiltbed trailer so don't need ramps or a dovetail. If you don't have a mid mower I don't see where you need a dovetail tailer.
   / Quick trailer question #3
As mentioned, the advantage would be decreased breakover angle when loading. But, My Brother and I have identical trailers, his is dovetail and mine is not. I used his before I bought mine and had to be very careful due to the dovetail dragging on uneven terrain (dips, railroad crossings. driveway entrances etc.) and this was the reason I went with no dovetail on mine, of course I don't have a MMM either. Just thought I would throw in this possible disadvantage of the dovetail.
   / Quick trailer question #4
I have a 5'X10' utility trailer with a 4' ramp/gate thats used to haul a BX1850 with a 54" MMM. Works Great.
   / Quick trailer question #5
Why I also wouldn't want a dove tail.
You actually haul a BX1850 on such a small trailer.
Do you think I could haul A BX1500 on my 6x8 trailer?
   / Quick trailer question #6
Yes, I have hauled my BX1850 over 500 miles on such a "small" trailer. I don't think you need a trailer with a 14k
capacity to haul a 2k tractor.
If its a well built 6X8 I would haul your BX1500 in a second.
Here's my trailer,
[/IMG]
   / Quick trailer question #7
Here's my trailer,
[/IMG]
I agree!
That's why I only have a 12K trailer for my 2K tractor!
90018 (A48082)
90018 (A48082)
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
2016 FREIGHTLINER CASCADIA TANDEM AXLE 6X4 MID ROOF SLEEPER TRUCK (A51219)
2016 FREIGHTLINER...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52128)
2013 Doyle Dry...
2019 PETERBILT 579 SLEEPER (A51222)
2019 PETERBILT 579...
