Welding
/ Welding #1
BrentD
Ok, so I haven't touched a welder since back in high-school in 1995 and that was an old 1950's or older tombstone Lincoln. Back then I was taking an Ag class thinking that would be the easiest way to weld. Unfortunately, school budgets being what they are, the class was held in an old maintenance garage with terrible lighting and the only welding helmets we had were probably shade 15.
Back then I was so nervous and blind through the helmet that I stuck the rod to the table more often than I was able to successfully strike an arc, and when I finally got the arc striking down I'd end up welding my workpiece to the table because I absolutely could not see when I got to the end. And yet, somehow I managed to pass....
Well, fast forward to the present. In one of those bizarre deals only Harbor Freight can come up with I got a welder for 25% off, then was able to use another 15% off coupon. I ended up with their 110 Amp 220V MIG welder for around $150. That was Last Christmas. Finally got around to using it for the first time today. Needed to make a new alternator bracket to fit a Delco 12SI alternator to my Geo Tracker.
Spent about 30 minutes doing test welds on the same thickness metal I'd be using for the bracket. Once I got a good understanding of how the MIG plasma flame melts the metal and the wire I was able to get decent welds fairly quickly. My auto-darkening helmet is an absolute luxury compared to those old flip-down Shade 15's from back in school. After I got the hang of controlling the welder I cut and drilled all the pieces for my bracket, cleaned them up good and then proceeded to weld my first actual usable item.
I'm sure it won't win any awards for nice looking welds, but it's holding together even after some fairly hefty whacks with the sledge hammer.
I do have a few questions after this first experience though... I had trouble controlling my wire speed. Seemed like it was either too fast or too slow. I was welding 1/4" plate, Mostly Fillet welds. At one spot near the end of one of the welds it looked like the weld bead sort of took a chunk out of the metal, so I turned my amps down and raised the wire speed. The big issue I ran into with most of my welds is that the bead is pretty thick. Looks like somebody over-did it with a glue gun. From the edges you can see that the bead is penetrating into the sufficiently though. I thought turning down the wire speed a little would give me a better looking weld without piling up so much metal on the bead, but it just gave me a sputtery weld that was more like a rapid series of arc strikes. I eventually just turned the speed back up and finished my job with the ugly welds. At least I know they'll hold.
Any suggestions for getting better control of the machine (apart from getting a better machine with dials for current control instead of switches)?
/ Welding #2
Using flux core wire? If so hard to get nice welds. 75/25 gas looks much
better.And you are welding 1/4 plate that would be max out on most 110 units.Good luck Framer
/ Welding #3
With fixed voltages you use wire speed & torch speed (technique) to control the puddle. Sounds like you wanted the torch to run hotter so you should have moved faster to counter the heat.
A good weld sounds like bacon sizzling in the pan.
When all else fails, read the instructions! :eek: My welder has a guide on the lid: Material thickness, voltage & wire speed settings for solid (c25) & flux core wire. Setting the machine to their recommendations before starting means minor wire speed adjustments at most.
/ Welding #4
Wire size has a big factor on welding. Welding 1/4 in. needs to have at least a .035 wire. You "can" get decent welds with flux core and in some situations it's better than gas. I've made the mistake on using to small of wire and my welds looked like crap and I didn't have any penetration.
/ Welding
Should have mentioned that I was using .35 wire. I totally get the bacon sizzling thing. I spent a whole 6-weeks trying to get arc welding down back in high-school and never quite got past being startled every time the arc struck. Thinking about that I was really nervous before pulling that trigger the first time today, but was pleasantly surprised by the nice steady hiss with just a bit of popping.
Also, I'm using solid wire with 100% argon. When I bought the machine I was planning on building an aluminum frame for a pontoon boat so I got the pure argon to weld aluminum.
The sticker in my welder is actually in the wire compartment. I was going by the general recommended settings for 1/4" in there. That's supposed to be about the upper limit of what the welder will weld, even though I did manage to burn a hole through one of my test pieces of 1/4" with the welder at full power. I think everybody is right about my speed though. I think I was probably trying to remember what I was taught in high school and probably moving the torch too slow and letting the metal build up. I probably didn't do too bad for a first timer. I'll try to get some pics of the bracket tomorrow, just don't laugh too hard when you see them. :p
/ Welding #6
think of welding this way. the voltage controls the profile (flat or not) of the weld, the wire speed simple put controls the amperage. The faster the wire reaches the work, the more amperage the machine uses to melt the wire. As the wire speed and amperage increase the voltage required to produce the same profile increases.
to set your wire speed here are the two main items to remember, if it is to slow it burns back to the tip, to fast and it hits the work and jerks. If you turn the wire speed up or down more than a small amount you will need to adjust your voltage.
The pure argon will work, I would have bought 75/25 for most welding and CO2 for junk iron. 100% argon cost a lot more than 75/25, and until you are ready to tackle your aluminum you don't need it. Also if you have a gas cylinder, most welding stores will let you exchange it for cylinders with other gases. I turned in my argon when it was empty for Helium to fill a bunch of balloons for my buddies wedding.
/ Welding #7
I concur with everything AKwelder said. Using pure argon with steel is not recommended and usually requires less voltage, and it sometimes leaves a hummpy, skinny weld with some undercutting. I can't imagine what caused the problem near the end unless it was "arc blow", or a base metal imperfection. I sometimes put a piece of scrap metal beyond the end of the welded piece to avoid arc blow ( i.e., the weld really ends on the scrap).
I assume when you said you turned down the amperage, you meant you turned down the voltage, but it seems like you have the concept down. If I had a hummpy weld I would have probably first turned up the voltage, and then perhaps down the wire speed, however. I think your problem is that the machine doesn't allow fine enough adjustments to get the perfect looking weld. Once you get the settings just right, the weld will look great and be strong. Switches (high, low voltage) just won't do that. You could grind the weld a bit if it looks real ugly, and then paint it.
I just bought a Millermatic 211 this last week with a Spoolgun for soft metals (i.e., soft wire). It is infinitely flexible and really fantastic, but the whole shebang (filled tank, cart, out the door) was 10 times the cost of yours, unfortunately.
/ Welding
I was mainly going by the chart on the front of the welder. It has 2 switches, One for Min and Max, the other for range 1 or 2. The settings go min 1, min 2, max 1, max 2. The chart shows a voltage increase for each step, but also an increase in available current. The change in available current seemed to be the more significant change on the chart, so that's what I thought I was changing. The voltage change is rather slight. From Min1 to Min2 the voltage only goes from 16 to 18 volts, but the current goes from around 20 amps to around 40 amps. (If I remember right the current steps are 20, 40, 65, 110).
/ Welding #9
.035 wire is too big for your machine I have 3 250 amp lincolns on my floor and unless we are doing structural steel we run .030
try using 5% helium 70% carbon dioxide 25% argon mix this will get more heat aout of your little machine mig isnt really accurate in this case since helium is not inert and will cause the wire to burn hotter.
heat is the problem trust me , a simple way to prove it is this: set the welder up as you were .start a bead slowly move your nozzle closer to the work ,does performance improve ? it should , think of the wire like a resistor longer resistor = more energy to melt it
also the bacon thing is kinda half right it should sound like bacon frying without the silences between it should be a sizzle with a slight little groan the more uniform the better , remember with welding usually if it looks good it is good
/ Welding #10
A good way to set wire feed speed is to place a scrap piece very close to the welder so you can easily reach the control knobs. Then weld and adjust wire speed until it sounds just right. The label settings are just a close estimate.
/ Welding #11
You just need a little more time behind the mask. You will get it figured out.
Good luck.
/ Welding
With all this talk about wire-speed I think I need to point out something else I noticed about my machine that doesn't seem right given what everybody is saying.... If I'm reading your posts right, the wire has to be in contact with the metal continuously to maintain the arc correct?
On some of my test welds I noticed something that doesn't match this description. On a couple of occasions with my test welds I set the wire speed ridiculously slow just to sort of see what happened. I struck the arc and the wire burned away but the arc dd not go out. It actually looked like a flame coming from the torch and I could see the wire slowly extruding from the handle then getting close to the hot part of the "flame" then a little ball would melt on the end of the wire and drop into the pool of metal. When I saw that I thought I understood what was happening. I thought the striking of the arc established a plasma flame (kind like a tig) then the wire feeder fed filler into the plasma flame to create the pool, but it's sounding like my understanding is either completely wrong or my welder is weird.
A few years ago I got the opportunity to watch a guy doing a lot of TIG work on a solar car's aluminum frame so a lot of what I know is based on what he told me and what I observed and read at the time.
/ Welding #13
Your gas cup should almost touch the work and be tipped about 30 degrees from perpendicular. Open up the voltage a little hotter than the directions, hit the trigger and adjust the wire speed till it buzzes (sizzles) tightly. The arc should be just hot enough to erode the vertical metal, but cool enough to "push" the puddle up to fill it back up. A flat test weld should blend in at the edges, and not over about 1/8" high. the wire will glob and fall into the puddle at around a 1/16". If it is hissing and burning the wire toward the tip, your too hot, or not enough wire speed.
/ Welding #14
No,mig is not plasma. What your doing is called short circuiting mig welding,your wire comes out,touches metal,starts arc,melts off [cause of this short circuit],and repeat,thats what you hear that sounds like paper tearing.
Now there are other mig process's that depend on how hot,how big a wire,what kinda gas, called spray,and globular.
What a tig torch does is same thing a stick rod does,except the electode is made out of tungstun,which don't melt easy,so you just maintain an arc,and add your cold filler,like oxy/act welding,same thing only tig,your arc is heat source,oxy/act,your flame is heat source.
You should try some CO2 or CO2/argon mix.
/ Welding #15
try putting a tungsten electrode in your stick welder and see if the process seems the same to you. its the puddle man allways the puddle focus on it love it, make it do what you want it to do, dont let the puddle push YOU
personally I am trying to get the funding together to get a truck to drive around the country picking up stick welders and throwing them off cliffs.
no disrespect to the stick welders of the world but I dont hunt with a spear or ride a horse to work
that being said I'm telling you man your machine is just small you must have a buddy with something larger or spring for one you will love a nice 185 amp machine hobart make a relly nice one in fact if you look in the background in a lot of the pictures on tbn you can spy one often .your welder is your best friend
/ Welding #16
p.s has anyone ever used globular mig technique ? and if so what for? isnt it actually a hybrid of spray arc and short arc only time Ive ever seen it is in a seminar or when a new guy hasnt quite figured out short arc . this is serious question by the way
/ Welding #17
Stick welders have their place and have the ability to do what mig and tig just cant do. Some examples:
Weld dirty, rusted metal. Yea you can clean, but sometimes you cant get into tight areas.
They can weld underwater with a proper setup.
They can reach into akward places that a mig gun or tig cant get to.
These are just a few examples, besides the fact that a good machine is dirt cheap compaired to a comprable sized mig.
And if stick was really all that out dated then why is most of the structrual welding in this country still being done by stick???
/ Welding #18
Welding is a skill that takes some time under the shield to get it right. The more time I spend the better I get. I think this is true for most people and I find it difficult to try to remember all the little things while trying to run a bead. But the more you practice, the more used to holding the stick or gun correctly you will get. It will become second nature.
About the machine in question, I would think that if you only have the capacity to select from four settings and can not dial in the wire speed and voltage you are going to have a hard time getting it right. Also not mentioned so far, what kind of flow rate for the shield gas are you using and do you have a flow meter to verify it? For .035 wire I run about 18 to 20 cft
and try to weld out of the wind for best results.
Steve
/ Welding #19
Funny...I was gonna make bug zappers outta MIGs..
I don't see the need to waste time fiddling with knobs,dragging the welder around the tractor,clearing nozzles,straightening leads,changing spools,refilling tanks,finding a calm place or spending all day on prep...I need to have things fixed.
/ Welding #20
... no disrespect to the stick welders of the world but I dont hunt with a spear or ride a horse to work ...
Why not? Imagine the change in attitude of your co-workers when you arrive at work on a horse with a spear in your hand. I mean, I work with some barbarians, but that would just set you apart from the rabble.
As for welding - to each his own. Stick works nice for me. As bobodu noted, there's a lot less fiddling with the machine and more time puddle gazin'.
-Jim
2018 CATERPILLAR 320 EXCAVATOR (A62129)
2018 CATERPILLAR...
UNUSED IRANCH MINI SEMI-AUTOMATIC QUICK CHANGER (A62131)
UNUSED IRANCH MINI...
2013 Mercedes-Benz E-Class Passenger Car, VIN # WDDHF5KB8DA693077 (A61569)
2013 Mercedes-Benz...
Kubota M5-111 Tractor with Loader (A61166)
Kubota M5-111...
2013 Ram 5500 Bucket Truck, VIN # 3C7WRNALXDG552597 (A61165)
2013 Ram 5500...
2015 Ford F-250 Pickup Truck (A61568)
2015 Ford F-250...
