tilt trailers
/ tilt trailers #1
gordyy
Gold Member
North Dakota
cub cadet yanmar sc2400 Kubota F2560
Any one on here using a tilt bed trailer to haul there gitter on
I am asking as I have a slight problem with my current trailer and my body
I have an artificial knee and have been having trouble with it since its been in the past year or two. One reason I went to the subcompact as I am a fair sized guy and needed a cab and heat do a lot of snow that sort of thing
anyway the Ramps are heavier on most trailer than my doc says I should ever be lifting again have used spring loaded ramps on lowboys and the like but seems the springs go to pot in just a year or so all the time.
I have been looking at em and just was wondering if any of you had them and were using them for trailer work
thanks Ken
/ tilt trailers #2
i dont currently own one but ya ive used a couple different tilt trailers and i really like them, i just hauled my skid steer last night on a dump trailer and the whole time i was loading and unloading it i was sayin i wish i had a tilt trailer, obviously theyre not as versatile as a dump trailer in that hauling large amounts of dirt or gravel or tree branches or whatever you wanna haul is limited, but as far as loading the tractor up and binding it down in my opinion its much easier, just be sure if you get one to get one with hydrualic dampening so it doesnt slam forward or back when youre loading/unloading. and the good thing is the heaviest thing youll have to lift is your coffee mug while youre using your loader to tilt it down to load it and bring it back up when you unload it. sorry a bit of a rant but ive really come to prefer tilt trailers, and im still a little bitter about last night having to use that dump trailer :rolleyes:
/ tilt trailers #3
Before I bought what I have I looked very seriously into tilt. The only reason I didn't go that direction is because I might want to load more than one thing at a time. If you are loading just a single vehicle they are probably the berries!
/ tilt trailers #4
I have one. I bought an H&H tiltbed trailer for my multi purpose use. Hauls, tractor, cars, trucks, or anything else I want to put on it. Mine deck is 20' x 82" between the fenders and the entire deck tilts. Mine came with a manually pumped hydraulic jack. The company also sells electric/hydraulic version. I converted mine from manual to electric/hydraulic tilt and added a winch. I also added my own D-rings (6) for tie down points or can use the stake pockets. There are several pics of it in the members photo section under other brands / mahindra on pages 5, 6, &7. Also my avatar. I really like it. Much faster than using ramps. I haven't had any problems getting anything on or off.
I have loaded my tractor and a 4 wheeler behind it.
/ tilt trailers #5
I have an old homebuilt (by someone else) tilt deck that I haul my tractor with. My tilt is pretty steep, ane the pucker factor gets a little high sometimes when loading and unloading. I still prefer it to the fixed deck I used to have. It's so much easier than using ramps.
I actually just bought an old used car hauler type trailer, and I keep finding myself wondering if there's a good way to convert it to a tilt. I still haven't brought myself to sell the old tilt yet.
/ tilt trailers #6
When I think of multiple items I usually referring to worst case senerio like 2 or more things that have no park brake and may not run either. Other thing is a gravity tilt snubbed or not may make multiple unloading impossible unless you have power or manual jack.
/ tilt trailers #7
I never had a tiltbed trailer for the tractor; had to use two metal ramps. But I did have a 5' x 10' tiltbed on which I would drive my Cub Cadet lawn tractor (riding mower) and a Kawasaki Mule occasionally. As for things that may not run . . . I moved a few big toolboxes for mechanics. These were toolboxes that weighed in the neighborhood of 800 lbs. or more empty, and they were full of the mechanics' tools when I moved them. I simply used a 4 ton come-a-long (winch) attached to the front of the trailer, then winched the boxes up the tilt. No reason I couldn't have done the same with a tractor that wouldn't run. I also used the same come-a-long once to winch a non-running Chevrolet Suburban up the ramps onto a 16' non-tilt trailer.
/ tilt trailers #8
We use one to deliver a lot of our machines with.
If your looking at a power up and down trailer.
I would say a must for someone with a bad knee is to get one with a remote control.
The angle of the bed will make it difficult to get on and off any machine.
It is neat to be able to drive up on and with a key chain push the button and the trailer levels.
You will be glad you spent the extra TRUST ME!
/ tilt trailers #9
I don't know what you mean by snubbed.
I'm thinking you mean wheel chocks which I also have used along with chains.
I have had many a rolling vehicle on my trailer that I had to winch on and chain down since they had no brakes such as cars and trucks with no drive trains. Two chains front and two in back held them in place.
I have had my tractor w/ loader, rotary mower, back blade and york rake all on the trailer at the same time with each item chained or strapped down.
/ tilt trailers #10
Snubbed is slang for hydraulic dampened.
I sometimes move ZTR's and riding mowers for a friend that has Cub Cadet business. I might have 4-6 on my trailer at once. I tried to think about how to do that with a tilt and figured it might be tough. For sure I would need a power tilt trailer for something like that. I kicked it around for over a year before deciding against it. Plus I wanted a deckover tilt and that added more complications to the mix.
/ tilt trailers #11
I made mine a power up and gravity down. Once tilted up you could drive up, park (set brake) then get another to drive up and park. It won't go down until hydraulics are released. The deckover tilt makes for a higher / steeper approach angle due to the extra height with the deck above the wheels which is why I went with this one.
/ tilt trailers #12
I have a large (9 ton) tri-axle, beaver tail tilt bed trailer. I really like the tilt bed when loading super heavy stuff, like the dozer I used to have. All the ramps really do is give me something to drive up which tilts the trailer. I find it easy to load a tracked vehicle as I have more room to work with than thin ramps when going up the incline while loading.
George, do you think you could post a picture of the tilting ram on your trailer. I'd like to install a manual bottle jack to tilt my trailer. I really can't get it to tilt with much less than 5000 lbs.
Thanks,
Joel
/ tilt trailers #13
/ tilt trailers #14
1* I converted mine from manual to electric/hydraulic tilt and added a winch.
2* Much faster than using ramps. .
1*Would not want it with out this.
2*I still want ramps too.
I have an old homebuilt (by someone else) tilt deck that I haul my tractor with. My tilt is pretty steep, and
3*the pucker factor gets a little high sometimes when loading and unloading.
4*I still haven't brought myself to sell the old tilt yet.
3*Why would the pucker factor be worse than it is with ramps:confused:?
4*why are you giving up the tilt for the non tilt car hauler?:confused:
5*I would say a must for someone with a bad knee is to get one with a remote control.
5* love this idea.
/ tilt trailers #15
You will be glad you spent the extra TRUST ME![/quote]
On our 38' tilt semi trailer, (30' lower deck) the empty deck is tilted up & down by activating the hydraulic. A loaded deck will let itself down with the load by having a low pressure by-pass in the hydraulic system. Works very good for all of our equipment. The poor mans remote. :rolleyes: We have loaded 2 machines on our trailer before, it just takes 2 people at the same time to load and unload.;)
/ tilt trailers #16
I also have a H&H 20 ft. tilt bed trailer that I haul my JD3320 about 100 miles each trip I make to the farm. (always bring my tractor home as I am concerned about thief of tractor and trailer) My previous trailer was an over the wheels, fixed deck. Usually loaded tractor from a loading dock but alway needed to support the rear of the trailer in some manner to keep from lifting back of pickup off the ground. I like the tilt bed very much but would also recommend the electric lift which I don't have. The trailer is about 9 years old and have not had any problems except for an occasional flat tire.
/ tilt trailers #17
3* I think it's the sudden motion thing. I have to be careful to keep the loader down and whatever I have on the 3 pt. down or else the front tires will "bounce" when the deck has tilted all the way down. I still prefer this to ramps.
4* Brakes!! The old trailer doesn't have electric brakes, and the new one does. The deck is lower too on the new one. The combination will make it a lot nicer to tow. The new one is also a little longer.
/ tilt trailers
thanks for the info guys
went and looked at a few different ones around here
thanks for the info on the electric
I also have been considering an air ram to replace the cylinder as my tow vehicle has air in available in it.
I have a power invertor and a small 4 gallon nail compressor that runs off it
thought of taking the air cylinder from my cherry picker and trying it in place of the ram that is in there a friend has a manual that we arre going to try my air ram in first next weekend if that works I might just have to go get me one
/ tilt trailers #19
Your post regarding moving mechanic's tool boxes reminded me of a very funny incident involving my car carrier and one very old heavy safe. It seems this guy bought a classic old western safe complete with steel wheels. I winched it up on the tilt bed, secured the load, and made the delivery with my car carrier (Ford LN700). As I was beginning to winch the safe down the tilt deck slowly, he and his buddies (beers in hand) asked me to just let it roll off the deck into the garage. I said "Not a good idea". They said (beer talking) "No problem, we'll stop it!". So...I cut it loose and away the safe went.
Those boys attacked that safe like a bunch of football players on the line. The safe pushed them ALL back into the garage with sheer panic taking hold and beers flying everywhere. They managed to stop the safe about one foot from Momma's nice washer & dryer set! Momma wasn't there to witness all this man stuff, but if she had been there, those boys would have been cowering like whipped dogs!
2015 Ford F-550 Crew Cab Flatbed Truck with Liftgate (A61573)
2015 Ford F-550...
2023 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2023 Chevrolet...
2015 HINO 268 4X2 S/A 26FT NON CDL BOX TRUCK (A59911)
2015 HINO 268 4X2...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
LILLISTON 8R ROLLING CULTIVATOR (A63291)
LILLISTON 8R...
2016 International WorkStar 7500 T/A Dump Truck (A61573)
2016 International...
