multi-blade mower deck orientation
   / multi-blade mower deck orientation #1
schmism
Super Member
Peoria IL
New holland TC(33)
anyone give any thoughts to the orientation of the blades on a multi-blade deck?
/// or -|- or something else?
finishing up getting my mower deck ready for the first cut (ya technically i could have cut once or twice already) of the year. Finishing up a 6-8 hr maintenance job. between sanding and painting rust spots, a complete cleaning, blade sharping, bearing inspection, grease all points and rebuilding a front caster wheel that died.
It occurred to me i wonder if there is some special orientation of the blades relative to each other.
   / multi-blade mower deck orientation #2
If I understand your question... Unless you have replaced the pulleys and belt with sprockets and a chain, you can set them any way you want. They will change while using them.
The belt will not keep the indexing while in use. KennyV.
   / multi-blade mower deck orientation #3
Nope. Any old direction is fine. You can align them parallel if you wish, but they won't stay that way long.
//greg//
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
2019 CHEVROLET SILVERADO 11FT FLATBED (A59575)
2019 CHEVROLET...
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
2017 Caterpillar 249 Compact Track Loader Skid Steer (A59228)
2017 Caterpillar...
Yamaha Golf Cart (A57149)
Yamaha Golf Cart...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
