PT 425 Robin Engine Problem
/ PT 425 Robin Engine Problem #1
mlhunter
NW Missouri
Hi guys! Its been a couple of years since I've been on here and I now have 165 hours on my Pt425 with (EH72?) 25hp Robin/Subaru engine. Overall I've been satisfied with no problems. However, yesterday I encountered something new.
After using the brush cutter for about an hour to mow the remnants of a 1 acre food plot I started cleaning up some bramble choked paths with it. After several minutes of that I stopped to clear some junk out of my left front wheel and the motor rpm went way up! I dropped the throttle back to idle and it remained running near what would normally be full throttle! At that point I decided I'd better quit and put the tractor back on the trailer and went home with it.
Back at home, I studied the engine's throttle linkage and read the online Assembly/Disassembly and Parts manual to see what all is involved. Pulling the tractor's throttle lever back pulls the governor arm toward the carburetor and moves it to full throttle. It appears that the governor arm should pull against its restraining springs to govern how much thottle opening there is depending on the engine load. At rest with little or no load there is no movement of the governor arm to do that which seems to be why the rpms remain so high with little or no load. Nothing appears to be broke and all springs appear to be functioning normally.The governor arm is tight on the vertical shaft that goes down into the block where the governor mechanical parts are.
Right now it appears that I may have to remove the timing gears cover to get to those internal governor parts.
Naturally it couldn't happen at a worse time! I would like to hear from you guys that are familiar with these engines to determine if I'm on the right track and if there is anything else I should be looking at before I start pulling the hydraulics off the engine to to repair it.
/ PT 425 Robin Engine Problem #2
not sure if this helps but I have same setup mine does the same thing occasionally pulled air cleaner off throttle plate was iced up started using additive to gas and problem has not resufaced since hope your solution will be as simple
Thanks for responding! That's good to know although its been above freezing when I've used it and its kept in my garage which is usually in the 50s so it wouldn't be iced up.
I talked to Terry at Power Trac and he said he had never heard of one of these engines having a problem with the governor so I'm hoping my problem ends up being similar to your problem
I trailered the tractor to the our local Robin/Subaru service center yesterday so I'll see what they come up with.
/ PT 425 Robin Engine Problem #4
last time I trailered mine to the local small engine/compact tractor repair shop was quite interesting it all started with "that's not a tractor" :confused: and no it is not a JD ;) popped the hatch for a look see, I think he is still hiding in the parts room :D:D
/ PT 425 Robin Engine Problem #5
Take it to a small engine shop. You'll likely get, "My God! That's a tractor." And that was from just a photo.
You just can't win with these things. :D
I retrieved the tractor from small engine shop yesterday. The Blue Springs, MO, shop mostly sells and repairs commericial mowers. They are very familiar with these engines and believe they are very good engines. They went through the carburetor twice and while they had the tractor running after the last time it backfired a few times then quit running all together and wouldn't start any longer. They checked compression and valves and that all seemed good. They have seen crankshaft keys break and cause problems like that. They believe the problem is internal to the timing gears and governor and will require getting into the engine to find the problem and fix it.
They were willing to fix it with an estimated 7-8 hours labor plus parts. The only comment they had was how heavy the tractor was (they mostly sell and repair commerical mowers).
To move on with it, I elected to save some money and bring the tractor back home, pull the engine, and repair it myself if I can. I built and re-built hotrods during my hotrod days and got back into it awhile while I had two teenage sons at home to teach them how to do auto repair work.
Robin Subaru has a detailed service manual and parts manual online in PDF format. They seem to be quite detailed.
The tractor was purchased in May, 2005. I'll be talking to Terry at Power Trac when I run into engine removal snags. If anyone has tips on how to move the hyrdaulics out far enough to clear the engine output shaft and get the engine out I would really appreciate it!
/ PT 425 Robin Engine Problem #7
thanks for the feedback keep us posted as to what you find
/ PT 425 Robin Engine Problem #8
I pulled the engine out of my PT-425 several years back and wrote up the procedure. There are significant differences in the machines, but a read through it will likely provide some useful information. I know some of the things I pointed out should apply to removing the engine from any Power Trac.
PT-425 Engine Removal Procedure
Good luck with getting it out. I hope your model is easier to work on than mine is.
Thanks for that info, good stuff! I was going to wait until Monday but I couldn't stand it and started working on the PowerTrac about 11:30 this morning. By 4:30 I had the engine out, the rear bearing cover off, and the blown governor in my hands. Some of the parts were laying in the oil pan along side the oil pump filter. I can find no evidence of any engine damage at all and the timing marks (luckily) were almost perfectly lined up indicating no issue there.
I have to say the process was much less involved than what you went through. After removing the battery, gas tank, and heat shield getting the hydraulics off the "engine to hydraulics" coupler the engine removal was simple. Two bolts and the hydraulics pushed back approximately 1.5"-2" and the engine was free, no uncoupling of any hydraulic lines.
Since there were no hydraulics hanging on the engine and it only weighs 100# dry I pulled it with a come-along attached to a heavy chain that was strung between two eye bolts from a previous project. In my younger days I would wrestle 100# around but I don't attempt it any more! You'd laugh at how I got the engine on to a bench beside the tractor but if anyone wants to know the details I can post that info.
The only sticky issue with the whole process was was getting the "engine to hydraulics coupler" off the rear (rear of engine, not rear of tractor) engine main bearing cover after the engine was pulled. It was extremely tight and took quite a lot of persuasion. There appeared to be some light rust on the crank shaft that may have caused that. I'll be cleaning that up before it gets re-assembled!
Since there is no apparent damage to anything other than the governor itself I'm inclined to just replace that and sew it back up. I also found I'm missing an exhaust manifold stud/nut combo and one other exhaust manifold nut so I'll fix that while I'm at it.
I am mystified as to why the engine suddently died on the repair guy as I can't find any reason for that. I did find that the gas tank was completely empty and I'm betting it just ran out of gas!
Anyway, parts will be ordered Monday and hopefully Tuesday I can get it all re-assembled. Thanks again for posting that link to your experience!
/ PT 425 Robin Engine Problem #10
It's good to know they are easier to work on these days. I think the most important change has been to move all the pumps to one end of the motor. The biggest headache with the Kohler powered version is getting both front and rear pumps clear of the engine, so that it can be lifted out.
I can see how having pumps on both ends of the engine would make it more difficult! If I had not have had a quick lunch in between and a quick trip to the hardware store for some 1/4 inch chain for an engine hoist connection I would have finished in approximately 3 hours (and I worked very slowly)!
I was very surprised at the type of coupler they used and how simple it is to mate the engine's shaft up to the hyrdaulics. Kudos to Power Trac for their PT425 Robin/Subaru engine to hydraulics configuration!
However....
Removing that coupler from the engine's front bearing cover was difficult. The coupler's housing unbolted easily. However, the only way only way I found to get the keyed sleeve removed from the engine's shaft was to force a tapered chisel between the keyed coupler sleeve end and the engine's front bearing cover. I didn't have to use a 4# hammer but I did have to get pretty "business like" with a medium size ball peen hammer. I alternated hammer blows 180 degrees to avoid any potential cocking issues. The only other way I could see how this could be done would be with a massive screw type puller and that would be a highly specialized (and expensive if purchased) tool. It didn't appear that anything was damaged by that process and hopefully that is the case.
The only potential re-assembly issues I can see are:
1) Aligning the crankshaft with the cover if it changed position during or after the cover removal;
2) Re-installing the coupler shaft sleeve to the engine shaft at the correct depth; and
3) Re-positioning the engine inside the tractor's engine well to get the mounting bolts up through it and the nuts back on to the bolts. This is one thing I think Power Trac could configure differently to make this easier to do.
I'm trying to decide what kind of bolt guides I might make and/or use on the 3rd issue. If you had the same issue how did you get the first two lined up?
Terry of Power Trac had never heard of a governor problem with this engine so my issue is probably a freak thing! I also noted that the Robin/Subaru engine's crankshaft and bearings are massive for this size of engine! I can see why this engine should last 3000 hours or more!
/ PT 425 Robin Engine Problem #12
Hmmm. My couplers were locked to the shafts with set screws. Once I loosened them, it wasn't difficult to get them off the shafts. Getting the stuck together couplers apart took some effort, as I recall.
Nothing coupler related was fastened to the engine housing on the Kohler, so I can't offer any suggestions there.
On my machine, I unbolted the engine mount and took the engine out with the mount still on it. I could never have unbolted the engine from the mount and bolted it back in with the mount still in the tub. I believe I mentioned that in the write up. Was your mount bolted or welded in?
There are a lot of things Terry has never heard of before. ;) Most of them seem to happen to people on this forum. :rolleyes:
When I went to install the coupler back onto the main bearing housing I found the key locking setscrew in the coupler. Apparently it was underneath and when I felt around under there I didn't feel anything and I did that twice! In retrospect I should have looked under it with a mirror! I didn't hurt anything by forcing it off but it sure made the job a lot harder than it needed to be!
There is no engine mount component per se. The engine is mounted directly to a rectangular plate welded to the bottom of the chassis. A long bolt (4 of these) is inserted from the bottom of the tractor through the chassis and plate, through a 2 3/4" long 1" metal tube, then through a hole in the base of the engine block.
Its a tricky thing to get everything lined up and the engine set in the right place for bolt insertion. Since I installed the engine three times (long story) I found a decent workable method was to put a board somewhat larger than the plate inside under the chassis and balance that on top of a jack. By moving the board around I inserted the bolts one by one through the chassis, then jacked it up until the bolts were upright and solid. Then it was a simpler process to get it lined up, slip it onto the bolts, and get the nuts started. I think this is something that Power Trac could easily improve on if they haven't already!
I used a come-a-long for engine lift. A chain hoist would also have made it a bit simpler.
I'm thinking of documenting the engine removal steps for my own use down the road if I need to do this again. I could post it if you think it would be helpful for those that have Robin/Subaru equipped tractors.
/ PT 425 Robin Engine Problem #14
Since I installed the engine three times...I'm thinking of documenting the engine removal steps for my own use down the road
Now that you have had so much practice and have streamlined the process, how about you pull it out and install it a fourth time while viedotaping.....
/ PT 425 Robin Engine Problem #16
I'll call baloney on that, my 2007 PT 425 with Subaru/Robin 25hp blew the rear main seal out at 2? or maybe it was 4? hours on the clock when the governor kicked the can and I know he heard about that one. I was lucky, no fire when the oil sprayed all over the engine compartment.
/ PT 425 Robin Engine Problem #19
That was polite, Chris.
Baloney isn't the term I've always used.
Phil
But this is a family friendly site, so we will have to leave it there...
Probably NOT! However, I do plan on documenting the process for future use. I hope to get that done this coming week.
The tractor is now running right except its doing a bit of rpm "hunting" at mid-low rpms. My brother who used to work on MO state road equipment said that is not abnormal with a new governor.
