Help Identifying Ford 555
   / Help Identifying Ford 555 #1
bobmelvin
Hello. I am trying to figure out what I own so I can get a manual and know what I have. I was told it is a 1984 Ford 555 backhoe loader. I was able to get some information from a plate on the engine. It says:
BSD Power Product
Serial D 913200
Model 333H BSD
Part (fuzzy with this - not clear) E2NN 6007
Engine Capacity 3.3L
In the back - this is not very clear either
Component 19-805
Serial CB 26068
Any help will be greatly appreciated. Thanks for the great forum!!
Bob
   / Help Identifying Ford 555 #2
The E2NN-6007-XX engine block part number indicates that it is a 1982 design level, where "E" = 8, 2 = 2nd year of the decade, NN = Tractor Operations. 6007 is the base part number for the block. About all that any of this information tells us is that the TLB was built after 1982.
There should be a vehicle ID plate on the underside of the hood which would show the vihicle Serial Number, Model Number and Build Date.
   / Help Identifying Ford 555 #3
Hello, all. New to the forum. Have the same question as bobmelvin. Found a plate with a bunch of numbers on it. They are...
Tractor No.: 0664136
Model No.: DF311F
Unit No.: 1C19B
Engine No.: 1B25A
Transmission No.: 1A13B
Rear Axle No.: 1A30B
Any help would be greatly appreciated. Thanks, all!
- TLC
   / Help Identifying Ford 555 #4
Tractor No.: 0664136 Ser No: C664136 C = Romeo MI Assy
Model No.: DF311F
Unit No.: 1C19B Build Date: 1981, March 19, Day Shift
Engine No.: 1B25A Build Date: 1981, Feb 25, Night shift
Transmission No.: 1A13B Build Date: 1981, Jan 13, Day Shift
Rear Axle No.: 1A30B Build Date: 1981, Jan 30, Day Shift
Model:
D = Power Class = 201 CID 3-cyl
F = Chassis = Industrial
3 = Design Level
1 = Fuel Type = Diesel
1 = PTO Type = None
F = Trans Type = 4X4 Torque Converter
Any help would be greatly appreciated. Thanks, all!"
- TLC
You are quite welcome.
   / Help Identifying Ford 555 #5
BSD Power product tag tells me the engine is a replacement complete, new engine not original to the TLB.
TLB data plate is on the LH side of the steering column/instrument panel cowl, IIRC. It is most definitely not on the underside of the hood on this machine.
   / Help Identifying Ford 555 #7
HI,
I am looking at a Ford 555 with serial; RB20004.
Seller says it's from 1988? is it correct?
Thanks in advance
   / Help Identifying Ford 555 #8
HI,
Thanks in advance
S/N should start with a C or A, then 6 digits. Don't know what your number is. S/N and date code can be found on LH side of steering cowling on an ID plate and on the transmission bell housing on the RH side just behind the starter.
   / Help Identifying Ford 555 #9
Sorry I cant help much on the newer machines, but you may want to post your own thread and more people will see it.
   / Help Identifying Ford 555 #10
Re: service/repair manual for Ford 555
i need a service/repair manual for Ford 555
but heres the hitch...it needs to be a free pdf download
Honda EM3500SX Portable Gasoline Generator (A55851)
Honda EM3500SX...
UNUSED WOLVERINE MPF-11 2500G 30" PALLET FORKS (A57193)
UNUSED WOLVERINE...
5' DISC HARROW (A57192)
5' DISC HARROW...
Kivel Quick Attach Forks (A56469)
Kivel Quick Attach...
2022 John Deere R4023 Self-Propelled Sprayer (A53485)
2022 John Deere...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
