Spreader PTO Spreader for subcompact tractors?
/ PTO Spreader for subcompact tractors? #1
bx24d
I currently pull a 130lb capacity "tow-behind" spreader with Kubota bx24 but would like to know if a PTO spreader would make my life easier. Are there pto spreaders made specifically for subcompacts? Can you control the width of the spread well? Are there other issues I should be thinking about? I'm currently fertilizing, overseeding 1.5 acers of grass 3-4 times per year. I also use my pull-behind spreader for sanding the 400' driveway which is about 10 feet wide gravel.
/ PTO Spreader for subcompact tractors? #2
This one should work well on a BX24:
FERTILIZER SPREADER P180 - Agri Supply
Note the significant delivery charge though. So shop the local farm stores to see if you can get one closer to the actual $367 that AgriSupply lists it for - before the crippling freight charge.
//greg//
/ PTO Spreader for subcompact tractors? #3
Consider a plastic hopper if there's any chance of using corrosive materials (salt, lime, etc.) or you'll need to clean a painted metal hopper out & spray it down.
I went the plastic hopper route to lower my maintenance chores down. Too many kids, too little time...
/ PTO Spreader for subcompact tractors? #6
If you have a TSC near you, they sell one made for the SCUT's Tractor Supply Company - CountyLine Mini Spreader Seeder. It's the XB model and is rated for 400lbs. You can control the amount of material that comes out from your seat with a lever and you can control the spread by lowering or raising the rpm's.
/ PTO Spreader for subcompact tractors? #7
I'm thinking of the M96 myself. Although it looks a bit bigger on Herd's site than on the link that Builder posted. That price on the used one is pretty good.
Bombarder Sea Doo GTI (A64127)
Bombarder Sea Doo...
LANDPRIDE 48" BOX BLADE (A65057)
LANDPRIDE 48" BOX...
1992 International 4700 1,200 Gallon Fuel Tanker Truck (A66736)
1992 International...
1995 CHEVROLET KODIAK C7500(INOPERABLE) (A67714)
1995 CHEVROLET...
CATERPILLAR 48" QUICK ATTACH PALLET FORKS (A65056)
CATERPILLAR 48"...
CATERPILLAR C1.5 LITER (CONDITION UNKNOWN) (A68842)
CATERPILLAR C1.5...
