Spreader PTO Spreader for subcompact tractors?
/ PTO Spreader for subcompact tractors? #1
bx24d
I currently pull a 130lb capacity "tow-behind" spreader with Kubota bx24 but would like to know if a PTO spreader would make my life easier. Are there pto spreaders made specifically for subcompacts? Can you control the width of the spread well? Are there other issues I should be thinking about? I'm currently fertilizing, overseeding 1.5 acers of grass 3-4 times per year. I also use my pull-behind spreader for sanding the 400' driveway which is about 10 feet wide gravel.
/ PTO Spreader for subcompact tractors? #2
This one should work well on a BX24:
FERTILIZER SPREADER P180 - Agri Supply
Note the significant delivery charge though. So shop the local farm stores to see if you can get one closer to the actual $367 that AgriSupply lists it for - before the crippling freight charge.
//greg//
/ PTO Spreader for subcompact tractors? #3
Consider a plastic hopper if there's any chance of using corrosive materials (salt, lime, etc.) or you'll need to clean a painted metal hopper out & spray it down.
I went the plastic hopper route to lower my maintenance chores down. Too many kids, too little time...
/ PTO Spreader for subcompact tractors? #6
If you have a TSC near you, they sell one made for the SCUT's Tractor Supply Company - CountyLine Mini Spreader Seeder. It's the XB model and is rated for 400lbs. You can control the amount of material that comes out from your seat with a lever and you can control the spread by lowering or raising the rpm's.
/ PTO Spreader for subcompact tractors? #7
I'm thinking of the M96 myself. Although it looks a bit bigger on Herd's site than on the link that Builder posted. That price on the used one is pretty good.
PORTA POTTY (A68842)
PORTA POTTY (A67714)
PORTER CABLE AIR COMPRESSOR (A68842)
PORTER CABLE AIR...
32ft Flatbed Equipment Trailer (A64553)
32ft Flatbed...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A63569)
2015 VANTAGE...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
