Yanmar 3pt
/ Yanmar 3pt #1
loulblades
Gold Member
Butler County, PA
MF GC2300/GC1725
I purchased a Yanmar 180D last year to do some mowing on a remote piece of property. I didn't really get to use it much until now.
What I have found out is that in using the 3pt is that it won't stay down. I have to hold the 3pt handle to keep the hitch from raising on it's own.
I haven't researched this in the user's manual yet, plan to this weekend, but wondered if you Yanmar owners can tell me if this is normal behavior or there is an adjustment to stop this "feature".
TIA
/ Yanmar 3pt #2
Is the lever actually moving up on its own like it just needs tightened or is the lever staying put but you have to push it down to keep the three point from lifting? Either way not normal.
Aaron
Parts@HoyeTractor.com
(940)592-0181
/ Yanmar 3pt #3
TIA
There is both a friction plate & a stopper on the YM180.
Danny
/ Yanmar 3pt
The lever is moving forward. If I hold it in place all is okay, except trying to keep it in one spot and drive.
/ Yanmar 3pt
The shaft that the 3pt lever is on has a nut on the end (and a jam nut). I tightened the nut and now it stays in position. Of course it is harder to move the lever.
Not sure if that is what you meant by tighten the friction plate but at least it is holding. Thanks.
/ Yanmar 3pt #7
is there a rod from the lift arms to the actuaor / lever arm. My 1500 has this, and its set to switch off the lift once the arms raise over a certain point. would this need adjusting?
/ Yanmar 3pt #8
Maybe a little too tight?
Danny
/ Yanmar 3pt
Yes there is a rod that connects from the lift arm to the control lever. I have been looking at it trying to determine if there is some adjustment required. So far I haven't come to a final determination.
2022 EZ-GO ELITE...
2020 CATERPILLAR 279D3 SKID STEER (A65053)
2020 CATERPILLAR...
2002 MITSUBISHI FG40K FORKLIFT (A66091)
2002 MITSUBISHI...
2013 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2013 Caterpillar...
Wooden rocking horse (A64557)
Wooden rocking...
TAG 48" QUICK ATTACH EXCAVATOR BUCKET (A65053)
TAG 48" QUICK...
