KIlling Weeds
/ KIlling Weeds #1
casboating
Slidell, La
Kubota L3400 HST
Happy Easter,
I have a piece of land 100'x300' with a ton of nasty weeds. What's the best way to kill these weeds for good and prepare the soil and area for laying sod. I've tried applying Atrazine, but the weeds reappear each year. I want to make sure i kill all of the weeds and prepare the ground before putting all of that expensive sod down. Thanks in advance for your advice.
/ KIlling Weeds #2
Put up a temporary fence and put goats on it!
/ KIlling Weeds #3
Happy Easter,
If sodding I would Spray with the round-up and weed-b-gone mixed together in same tank and let them sit for a week or two then till and level for sodding and place the sod. Once the sod is placed most weed seeds should be too deep to germinate. Let the sod get established well (meaning you had to mow it at least twice) and do your normal lawn weed control. If neighbors and dust is not a problem you can follow the steps below but sod in the fall instead of seed.
If seeding and blowing dust is not a large concern you can get a good start with a mixture of Round-up and Weed-B-Gone in same tank that will kill almost all weeds. There is no way to completely stop weeds from reappearing in one fell swoop there are too many dormant seeds in the soil. Every time you disturb the soil you bring new seeds up to the zone of soil that they like for germination and bingo New weeds. After spraying keep on tilling the area as new weeds appear. When you till do not make the soil fine I'd use a cultivator not a tiller. Wait as long as possible before tilling as you must till them under before the first weeds go to seed. Some weeds will germinate early, some mid-summer and others early fall. So I would till the entire area for the whole summer. I would then till for the last time late summer (you could use a tiller here) before you want to seed and get the soil leveled so that when seeding time comes you have as little dirt as possible to disturb. Moniter and spray out any new weeds and then seed sometime in early fall (September). Keep the area watered and hopefully the grass seed will sprout and get established. Next spring you'll get weeds but wait until you have mowed the grass a couple of times then you are safe to start the normal lawn weed control.
/ KIlling Weeds #4
Best If you have a lawn & garden center with a horticulturlist that you could ask You wouldn't want to spend alot of $ on sod & it die from the chemicals you use
/ KIlling Weeds #5
I think there is a problem because most products that absolutely prevent weeds from coming back will be detrimental to sod.
Products like Roundup do not have the residual effect since they go after the living plant. I've used Ortho Triox and it prevented anything from growing where applied.
I've also had good success taking over neglected landscaping by using a Weed and Feed product, over seeding, using topping soil and proper watering. It takes time, but the results are amazing if you have the time.
/ KIlling Weeds #6
If your going to sod with bermuda then you can apply weed-be-gone as concentrated as you want. The one thing I really like about this product is that I've applied it directly to bermuda in full stength and it didn't harm the grass at all. Weed-be-gone only attacks broad leaf plants so bermuda won't be touched.
/ KIlling Weeds #7
I don't know where you are located. I'am down south where we generally have mild winters & early springs..Spring usually means that all the weed seeds are just waiting to sprout... Weeds are a constant problem here. I have my yard sprayed professionally year around & they still have a difficult time keeping the weeds out
/ KIlling Weeds #8
Roundup will pretty much kill everything. My wife is animal conscience about spraying chemicals. I'm OK with that. If I spray Roundup on the fence lines then the horses and dogs have to be taken away from that fence line for a week or until after the first rain. Whichever comes first. As far as broad leaf removal 2-4D seems to be the best. I have used 2-4D in the past. Good stuff. She says not to spray 2-4D now. She says it is a known carcinogen. I'm not sure what Weed-B-Gone has in it. I'm an old man and have been exposed to chemicals that are forever banned now. Least I can do is not put my critters through the same exposure.
/ KIlling Weeds #9
Weed-B-Gone is a formulation of 2-4D. Round-up kills or damages anything green but does not kill creeping jenny effectively (many names for this weed) and a few other weeds. Weed - B -Gone does a good job on creeping jenny. Round-up and weed-b-gone both have to be absorbed through the leaves and becomes inactive in the soil and will not leave behind a residual that will damage sod or grass seed.
/ KIlling Weeds #12
Happy Easter,
I have a piece of land 100'x300' with a ton of nasty weeds. What's the best way to kill these weeds for good and prepare the soil and area for laying sod. You will never kill the weeds for good I've tried applying Atrazine, but the weeds reappear each year. I want to make sure i kill all of the weeds and prepare the ground before putting all of that expensive sod down. Thanks in advance for your advice.
Once again I will reiterate....you will never kill the weeds for good. However if you work up the ground for laying sod...then lay your sod.....GENERALLY mowing will keep most of the weeds out. Make sure you keep your sod healthy and well watered and it will GENERALLY provide a barrier to choke out most weeds.
Spraying weeds in grass.....2-4D will kill most broadleaf weeds if they poke their nasty heads up through the grass. After your sod is established there is a variety of pre-emergence type of chemicals that will help.
/ KIlling Weeds #13
Hey folks,
Just to throw some more into the mix.
Round-up (or other brand name for glyphosphate) will kill just about everything that is green. If I remember correctly it disrupts the plants photogenic processes -- plant starves to death. It is absorbed thru the leaves and if accidentally gotten on something can be washed off with dirty water (it binds to the dirt and breaks down -- heard of phosphate in fertilizer?) if done immediately (before it has a chance to be absorbed and dry). I have been told that a human could drink the Round-up spray with no ill effects (I don't think I want to try it personally).
2-4-D is the main ingredient in Weed-B-Gone (Ortho) and most other weed killers and weed-n-feed products. It only will affect broadleaf weeds and plants. (doesn't kill grasses and narrow leaf plants). I have always thought of it as a broadleaf growth hormone -- the weeds grow themselves to death. You can not use it on newly planted grass, the grass need to have been mowed a few times. 2-4-D was one of the ingredients in Agent Orange and is pretty nasty stuff. It remains active in the soil and will effect plants that germinate -- don't spray a patch and then expect to plant a vegetable garden.
KBH Tender (A63118)
KBH Tender (A63118)
Case 1083 20ft Corn Head (A63118)
Case 1083 20ft...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63118)
2023 Takeuchi TL6R...
2016 Chevrolet Silverado Pickup Truck, VIN # 1GCRCNEH0GZ236549 (A61165)
2016 Chevrolet...
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A62131)
UNUSED WOLVERINE...
BUNDLE OF (1) TOPLINK & (2) LIFT ARMS (A62130)
BUNDLE OF (1)...
