landscape grader almost finished
   / landscape grader almost finished #1
waterguy
Maine
Mahindra 2615hst
I have been reading the posts for about a year so i thought i would finally join. I am just finishing building a landscape grader based on i post called rons grader. As soon as i test it i will post with pics.
   / landscape grader almost finished #2
Welcome to tbn Waterguy.Looking forward to pictures.Framer
   / landscape grader almost finished #3
Im sure theres lots going to want a look.
   / landscape grader almost finished #4
In your head line you posted a Landscape Grader.
Do you expect to grade sodded areas? The ones I have seen are for repairing roads. Not sure if they would work on sod.
   / landscape grader almost finished #5
Mine worked pretty good at peeling up a grass area for my driveway expansion. I look forward to seeing some pics Waterguy.
I plan on using it on my driveway. I now use a bedspring with weights and a chain link fence.
Didn't take pics yet, but my brother and i took it out to test it. Dragging it around showed me that even at 400 lbs the tail end is a little lighter than i wanted. When my 240 lb brother stood on the back it was real good at leveling my driveway. So we went on a mission to see if any friends had any railroad iron that i could place on the back. Nobody had any but when we were driving home i saw a piece near my nieces house. Her husband had three pieces that totaled 10'. He said if i made him an anvil out of one small one i could have them. He also told me where to get 10' more. This should do the trick.
It still isn't done as i need to make some changes, but here are some pics
   / landscape grader almost finished #9
Very nice - looks like it will do a great job!
I am adding 275lbs railroad iron on the back. I temporarlly tried it with it on the rear shelf and it made all the differance in the world. might change the rear leveler to an angle piece also, but i am going with the weight first.
2011 MACK CHU (PINNACLE) (A58214)
2011 MACK CHU...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
2014 REITNOUER MAXIMISER 48' FLATBED TRAILER (A58018)
2014 REITNOUER...
2010 KMC 3376 Peanut Combine (A56435)
2010 KMC 3376...
2001 Ford F-550 (A56858)
2001 Ford F-550...
