Serious tree mulcher .
/ Serious tree mulcher . #1
Eagleview
Orstraya , Ex convict stock , G'day .
It seems this guy was not impressed with the machines available for mulching , so he built his own . Based on a CAT track loader with a 420hp C12 CAT engine hanging off the back , with a belt driven self built mulching head on the loader arms . It also has a rear mounted winch . Have a look at the thickness of the mulcher body in the picture of the rotor . I'd love to see it in action , it's for sale for $350,000 AU .
/ Serious tree mulcher . #2
Pretty impressive to take on that build. It looks pretty well done. Im curious as to why he went with a belt drive over hydraulic? I cant think of another direct belt drive mulcher off the top of my head.It'd be cool to see a video of it in action.
/ Serious tree mulcher . #3
Belt drive is more efficient than hydraulics: just figure that a belt drive needs no additional cooling: the need for cooling means that mechanical energy is lost into heat...
I do wonder how he tightens those very long belts though...
/ Serious tree mulcher . #4
Re: Long belts. Yeah thats what i was getting at. I know belts are more efficient, but its a long way from the power pack to the head. Even if he used several short belts, it could be a nightmare.
Also dont forget that he'd need some sort of a clutching arrangement to prevent burning the belts if the rotor jams (which can happen a fair bit with a mulcher)
If you look at the first picture you can see a downward facing protrusion just before the rotor pulley on the belt cover . I would say it has a spring loaded idler to keep the front belts tight . There would obviously be a pulley at the loader arm pivot point where the front and rear belts meet so lifting the arms would have no effect on the belts . I would guess that the C12 engine would be running at low revs , using it's available torque to give good fuel economy and the rotor speed increased by the use of maybe a 2-1 pulley ratio . I would think it would be more efficient than running a hydraulic pump at high revs with all the associated losses .
2018 Hino 195 20ft. Box Truck w/ Electric Liftgate (A64556)
2018 Hino 195...
John Deere Bird House (A64557)
John Deere Bird...
2023 New Holland C327 High Flow Compact Track Loader Skid Steer (A64553)
2023 New Holland...
2020 JOHN DEERE 333G SKID STEER (A65053)
2020 JOHN DEERE...
Front Tank Bracket (A64126)
Front Tank Bracket...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
