Weighing in?
/ Weighing in? #1
dodge man
Super Star Member
West central Illinois
JD 2025R
I doubt this ever comes up for me, but you never know, if you are a pick up truck pulling a trailer and tractor, do you have to weigh in at weigh stations? My pick up weighs maybe 5600lbs and the tractor and trailer, 4000lbs.
/ Weighing in? #3
Probably not but as in real estate, location, location, location. Here is a link I just found on another site today actually. I saved it to check out when I get a chance. Might be some good info there.
/ Weighing in? #4
Even if you are commercial (not necessarily USDOT #), some states care, some don't.
In Colorado, I specifically asked the Deputy Chief of the State Police, scales this question.
He replied.
Under 26,000lbs , do not drive into the permanent weigh stations.
BUT
you do have to stop for the temporary DOT inspection stations.
So, that's colorado
Call whomever runs the scales in your state and find out, each state is different.
/ Weighing in? #5
He replied.
BUT
So, that's colorado
Actually MOST states have adopted the DOR regs 'In Toto' and the 26K is the threshold for a CDL. Some states require a fuel tax stamp and DOT # for anything over 18K.
/ Weighing in? #6
in OK our scale house's were run by Oklahoma Tax Commission employees. A couple of years back the scale house's were turned over to the Oklahoma Corporate Commission. Our ODOT folks have zero to do with the running of the scale houses. They are only open 5 days/40 hours a week and some are closed most of the time, so their really a joke here in OK.
ODOT and weights certified OHP troopers are the ones that will nail overweight commercial or non commercial vehicles at any weights. Most are looking for 2500/3500SRW trucks pulling the bigger Case b/h's/overweight dump trucks/etc for example. Pickup truck pulling a tractor isn't high on the priority list.
/ Weighing in? #7
* fuel tax stamp
Why would you need a fuel tax stamp when you pay the tax at the pump whenyou buy the fuel?
/ Weighing in? #8
interstate travel requires a fuel tax decal [IFTA] and some states require it for intrastate operations. NJ does for anything over 18K.
I've had Intra GA units [H plate] w/ temp permits get a hard time from GSP due to no IFTA decal coming back into GA...though they don't need one in GA...
/ Weighing in? #9
I have adopted the "Stop at all Weight Stations, Ag Stations and of course DOT stations!" If you read the signs that some stations they tell pick ups to stop! But I only do this if I am towing a trailer! I have been sent across their weigh scales so that the axle loads were checked ... Most of the time I just get the green light to keep rolling!
Leo
/ Weighing in? #10
Years ago I stopped while pulling a travel trailer in Indiana. They told me to "get out of there!" They seemed mad that I would go through the weigh station!
/ Weighing in? #11
I have found that they will come out of the scale house and let you know if you should have stopped, in IL. As for the portable scales if they don't flag you in don't stop. (only applies if drive a pickup not a big truck).
/ Weighing in? #12
LOL!
Years ago when I moved back from California to Illinois I was driving a 24' Uhaul with a car hauler on the back loaded. Went the southern route through Oklahoma to get as far south of the snow as I could. I thought I was following the rules posted as I went by the scales and in Arizona I was told I was not commercial so I didn't have to stop so I figured the same in Oklahoma. Drove right on by the scales in Oklahoma and soon found out I am indeed suppose to stop! Got chased down by the DOT and was sternly explained I WILL need to stop at the next scale "BOY!" I said yes sir and he let me go without a ticket. Now I suppose it's changed, this was probably 19 years ago.
/ Weighing in? #13
I've wondered the same thing before. Is it for commercial vehicles only, DOT stickered trucks only, over 26k lbs only, or what? What if you are driving a 3/4 ton truck pulling a tandem dual 20k gooseneck? Would it make a difference if you are hauling your own equipment and running a "FARM" tag?
And if you do have to stop, in what ways can they determine that you are overweight? Do they go strictly by the # of axles, the GCWR or the truck, the GVWR of the trailer, or all? I guess the weight ratings are specified by manufactures, but does the DOT use these to see if a truck is overweight?
/ Weighing in? #14
First clue to even be looking at a rig like that is a 20K trailer behind a 3/4 ton. That is in the F-450 class. Most 3/4 tons have about a 16K max tow rating on the 5th wheel and maybe less depending on gearing, options, ect. To check it all they need to do is first weigh the truck to make sure its weight is not over the max GVWR, on my F-250 this is 10,000# That weight will include the weight of the pin load from the trailer. Next they weigh just the trailers axles to make sure it does not exceed the GVWR of the trailer, lets say its a 14K trailer. If that is all ok the last thing they will do is add these weights together, lets say the truck was at 9,500# and the trailer was at 12,500# and that will give them the GCWR and as long as that does not exceed your trucks limits you are legal. In the example give 9,500+12,500=22,000# and my F-250 has a max GCWR of 23,000# so all would be fine and legal.
In Indiana it is illegal to pull a trailer with a GVWR higher than the tow rating, even empty. So for example a 20K trailer may weigh 7K empty so even though that is well within my F-250 or my F-350's tow ratings it is illegal to pull it because it exceeds the 16,300# or so tow limit.
Chris
/ Weighing in? #15
The trailer has a 16k GVWR and your 3500 drw truck is registered at 12000 GVWR. That makes 28k combined. If your commercial you purchase a 28k combined plates or tag. Dot can ticket you for being over 28k.
Dot will nail you for being over the trucks front or rear GAWR's. Example is the 3500 DRW Dodge with its 9350 RAWR. Thats why 3500 DRW trucks with theose big RAWR numbers are popular with "legal" commercial haulers.
In OK we can register a 3500 DRW truck for 15k for combined plates only. BUT the trucks RAWR are still used when weighing. If I'm not mistaken TX can register their trucks for what ever GVWR the operator want to purchase but again the trucks axle rating will come to play. Thats why we see many 3500 DRW trucks with a dot showing 30000-35000 lb on the door.
I would check with your state dot as to how they use GVWR/GAWR/tire caps when weighing a combined load. Even if your not commercial.
TX dot with portable scales nailed me in Lubbock for being over on the trucks rear axle numbers. I had a 36' GN with wheeled equipment and was allowed to move some weight off the trucks rear axle and not go over the trailers axle numbers. The sum of the trailers axle rating = the trailers GVWR.
In my post above I mentioned ODOT doesn't operate Oklahoma's scale houses. There all Oklahoma Corp Commission boys. Most of the time they green light a pickup of any size across the scale and do a paper work only. DOT isn't even involved with the scale house. BUT by ding dot field officers is very busy with road side weight/paper work checks/etc just about anywhere. Interstates or county roads.
/ Weighing in? #16
This is causing alot of grief for farmers and such. I think Alabama passed some sort of farm exemption, but in my brief search I was not able to find anything about it.
Certainly the auto makers are quite conservative in their GCWR, but how do they come up with this figure?
Too bad they just don't stick with the big boys. They are forcing some people to overload because of these restrictions.
I talked to someone here in AL that was driving a Dodge 3/4 ton truck and pulling a 14k trailer. He was not able to get a CDL for medical reasons so he went with the lighter weight truck trailer, yet he was hauling an CTL and mulching head which was probably around 12k.
/ Weighing in? #17
Rutwad - Ala no longer has the exemption ... That ended several months ago ... They are using a lot of portable scales and have built several road side turn outs to pull trucks over! This is true in Central and Eastern Ala. I know. Where I have a farm! I have a 3500 and a couple trailers so I have found a place to safely, I hope, leave my 6420 (12K with FEL) ... by the way GA seems to be really watching for the DOT Number on the truck and making stops of rigs!
Leo
/ Weighing in? #18
em14, I did not know it ended. I don't tow so it doesn't affect me, but it still sucks!!!
/ Weighing in? #19
...Most 3/4 tons have about a 16K max tow rating on the 5th wheel and maybe less depending on gearing, options, ect...
If the GCWR depends on things like gearing, options, engine size, etc, do the enforcement people actually check or care about this when doing a weighing? Most pickups don't have a tag on them saying what the max combination weight is. Are they really going to be concerned if you have a 3.7 rear end vs a 4.1, or gas versus diesel?
/ Weighing in? #20
They can find out real easy. Type your VIN# in Google some time and see what it comes up with. They have the info and will and can find out all they need to know if you give them a reason too. I have been lucky this far and never been checked.
Chris
2003 MAC TRAILERS 45' WALKING BOTTOM TRAILER (A60430)
2003 MAC TRAILERS...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
207270 (A52708)
207270 (A52708)
2021 FREIGHTLINER M2 106 4X2 24FT BOX TRUCK (A59906)
2021 FREIGHTLINER...
60'' Skid steer bucket (A61567)
60'' Skid steer...
2018 Chevrolet Cruze Passenger Car, VIN # 1G1BC5SM5J7145503 (A61165)
2018 Chevrolet...
