Lookie this!
/ Lookie this! #1
ToolcatWonka5610
Gold Member
Mount Morris, Michigan
Used PT1850 for sale on Power Trac's website :D
Used Power Tracs.
I think this would be perfect for us. Attachments and trailer. 310 Hours! :eek:
But I'd like to know some things to look for in a used 1850. (Problems, etc?)
What advice do you guys have?
/ Lookie this! #2
Located in Burlington Vermont, so it would have seen some rain and some snow. Sounds like they didn't use it much for snow as they only have the bucket (and a small one). Oh, its the 4-way.... Still. Not very snow friendly setup.
IMO price seems a bit high, actually very high.
I love the accessory list, two of those items I need and do not have.
Maybe if they threw in the trailer it would be more of a deal.
As for problems, who knows... You won't know till you see it, drive it, and quiz the owner down. If he was sole operator of the gear, probably a safer purchase. If a bunch of his employees used it, you will have a machine probably not as well maintained.
/ Lookie this! #3
I would ask the seller why it is for sale, and what issues they have had with it.
Generally, PTs are simple: Engine, pumps, hoses, motors, valves.
Mostly: Look for oil leaks.
Check for worn hoses at the hinge for the oil cooler and on the front motors where they come trough the front wall. Feel under hoses in the tub for hidden oil leaks and frayed hoses.
Check that everything runs when hot. PTO, brakes, steering, lift, draft control.
Unless they dumped it in a pond, it should be in pretty good shape. 310 hours in three or four years isn't much.
You might want to check to make sure that the tilt switch on the seat is functional; the seat is at an odd angle in the photo.
I'm with Woodlandfarms. I'd go for the trailer as well at that price.
On the other hand, it is nearly new, but no PT warranty. :)
All the best,
Peter
/ Lookie this! #4
Just FYI, that is the way the seat works on the 1800 series. You let it sit, and it drains down (Actually, I think oil is forced into the seat cylinder but have never paid attention to why). But all 1800 series tilt when at rest.
Also, there is a switch on the dash that turns off the seat. For me, this switch has never worked. My seat continued to activate, or actually just start leaning.
So I use that switch now to operate an aux circuit, one that powers my sprayer and electric winch.
Also, for anyone ever trying out the 1850, the seat gets some serious getting used to. It is always on the move (subtle usually) and sometimes it never goes to the correct upright position. It will give your midriff a good workout (someone accused me of pulling a brittney - going fat to skinny) because of this seat.
/ Lookie this!
Also like the attachments it comes with. Everthing we'd need (ex. a Power Rake). We do need the Boom mower and Stump cutter. The 4n1 bucket will be good to have but were still gonna buy a standard 60" 9cu ft Bucket. The 90" mower will be great for Brush hogging and Mower large lawns (and gets the smaller ones done faster :D).
How does the 90" mower cut on lawns when changed to a Finish mower (Finish Cut spindles)?
/ Lookie this!
??? Never heard of this. Something Terry recommended? Swapping the spindles would be no fun in my book.
The standard 90" Rough Cut mower comes with 3 Stump Jumper spindles for when your mowing Tall Grass, Weeds, and small brush. These spindles can be changed to Regular Finish Mower spindles and hass standard Mower blades. This set up is for mowing lawns.
/ Lookie this! #8
I am going to step out on a limb on this one. Take a look at the picture below. Now, I only know my little lawn mower and have never seen the underside of a grass mowing tractor mower. One thing I learned here was that the blades need a bit of lift built into them to cut grass better. Also, from what I can tell on my little gas powered mower, the body of the mower deck is designed to help with that suction. If you look at the bottom of the PT deck, well, not much design work for airflow. I had custom blades made for my PT, hardened, and then the edges upturned. I guess the mowing of grass is a bit better due to the suction, but I will tell you the amount of dirt I now have to breath is impressive.
1998 Mazda B2500 (A57149)
1998 Mazda B2500...
2009 JACK COUNTY KILL TRAILER (A58214)
2009 JACK COUNTY...
2021 FORD RANGER (A60736)
2021 FORD RANGER...
40' High Cube Multi-Door Shipping Container (A60463)
40' High Cube...
2461 (A58376)
2461 (A58376)
2019 VERMEER LP573 XDT VACUUM TRAILER (A59823)
2019 VERMEER LP573...
