Post setting
/ Post setting #1
RobertN
Super Member
Shingle Springs California
New Holland TC40D
What is the best way to set wooden posts? Soon, I will need to set treated peeler cores and redwood posts for fencing. Should they be set with concrete? Or gravel? Or, just with dirt? Why?
I have the auger on the tractor, and will be digging holes in the next week.
I am curious which way to set them, both for sturdiness, and longevity.
/ Post setting #2
Robert,
I'm sure I don't know the "best way" but this is what has worked for me. I use split cedar and don't skimp on the size. These are split in a sorta triangular shape ~ 10"-12" on a side with sap wood removed. No treatment and directly in the ground with only gravel added to the bottom of the hole for drainage. Below ground and above ground they have no rot, at ground level they do rot but in 25 years still straight and strong. My fences are mixed, some barb and some hog wire. If you set them in with concrete still add gravel to the hole for drainage and crown the cement up at the post. Never had much luck with treated stuff other than railroad ties.
/ Post setting #3
I dont know if them things work or not
but if those gals in their t-shirts come help I might put em on my pole barn
course that might be a way to find out what half of everything I own is worth
/ Post setting #4
Good Evenin Robert,
I have put in some split rail fence on my property, using my PHD 12". I just went down about 2 ft with the auger, put a few small rocks at the bottom of the hole and back filled with dirt tamping it firmly every few inches while the post is plumb. Although you dont have to worry about it in your local, up here in the north country we do have some frost problems occassionaly, and without using concrete I can reset the post without much difficulty.
/ Post setting #5
Evenin Gordy,
:DYou got that right !!! :D
/ Post setting #6
You all do realize that the original post is seven years old and that in the last 24 hours MrMagoo revived at least six different old "setting posts" threads offering how good the "post protector" product is... I'm thinking there's a connection.
Mike
/ Post setting
Mike
I know! I saw my user name there, and didn't remember the post. I did not look at the date, but thought someone figured out my password etc and was using my accnt :eek:
Then I saw the date, and tried to think back to what I was doing back then. Besides banging rocks with my post auger :D
/ Post setting #8
In that case how's the posts holding up over the last 7 years?
tom
/ Post setting
tom
They have been doin ok. Except where the mother in law knocked one over :D Can't put the fence too close to the main drive :D
The electric jack hammer was sure a lot more useful than the post hole auger though :eek:
/ Post setting #10
old post.. but here are some good tidbits since the post has now revived and others are reading it...
dirt.
concrete will rot them.
remember.. a fence post is a friction pile... dirt will provide more surface area contact vs a larger gravel.
you can google 'friction pile' for more info on how they work / why they work. striaght lift.. not so strong.. a lil side load and lift.. big time strong.
longevity? trat them with copepr napthenate.. IE.. set them in a 5g pail and let them soak for a bit.. stuff bills / deters rot and bugs for decades.
watch out.. it's a more or less permanent green stain.. and it will remove HAIR.. ;)
soundguy
/ Post setting #11
My HF electric hammer has paid for itself many times over for the amount of post holes that I have used it on. I need to get a four foot bit for those deeper holes that my three foot bits fall short on. Don't know that I could lift the darn thing by the end of the day though.
/ Post setting #12
I'm glad the post was popped back up. Looks like the "advert" post was removed.
I have been trying to decide if I should use all of the red cedar we have for posts. From comments in other posts, no pun intended, it looks like red cedar posts will last. Seeing a post from Twinkles from 7 years ago is just more info. :) And Soundguy's suggestion of using copper napthenate.
Later,
Dan
/ Post setting
We have rocks all over the place. And, in the summer, the clay here is hard as a rock. Living in the middle of the classic "Gold Country"(I'm only 15 minutes form the gold rush discovery of Coloma), I wonder how those gold rush miners ever dug any thing up with just picks and shovels.
We have a pointed bit, and a spade bit. Pointed bit for rock, spade bit for hard clay.
2006 John Deere 35D Excavator (A63109)
2006 John Deere...
Bobcat 873 (A55272)
Bobcat 873 (A55272)
2017 CHEVROLET 5500HD LCF S/A 4X2 24FT BOX TRUCK (A59910)
2017 CHEVROLET...
2008 Ford E350 Armored Car (A64047)
2008 Ford E350...
Homemade Trailer (A63116)
Homemade Trailer...
240156 (A56859)
240156 (A56859)
