Remote Control to Release Bucket
/ Remote Control to Release Bucket #1
hog
Maine
New Holland TC40DA
Has anyone built a remote release for the quick attach bucket so you don't have to leave the tractor when changing attachments on the front end loader? If so I would like to look at some pictures. I think this could be done with an electric actuator. Any ideas?????
/ Remote Control to Release Bucket #2
I have uses some payloaders that had some type of electric over hydraulic actuators to unhook and hook the bucket or whatever attachment being used. Last one I used was a brand new New Holland W80 that had it on.
/ Remote Control to Release Bucket #3
check out bobcat's "power bob-tach"....
/ Remote Control to Release Bucket #4
Quite commonly done with a solenoid valve to divert bucket circuit oil to a latch operating cylinder on the QA device.
/ Remote Control to Release Bucket #5
The other day I was at my local Kubota dealer, and they had a small Kubota front end loader with a skidsteer style QA bucket. It had a hydraulic cylinder to operate the QA locks, allowing you to change buckets/attachments without leaving the seat.
/ Remote Control to Release Bucket #8
I believe that all of the Power-Tracs feature this as standard. But their QA is their own style, not standard...
/ Remote Control to Release Bucket #10
OK, now we are getting lazy. Pretty soon we will want remotes so we can run the tractor while sitting inside watching TV. I wish I had a remote control to load up my 3PH when I change from blade to rake! Now, that's a PIA!!! :D
/ Remote Control to Release Bucket #11
If you don't get off to latch your QA bucket, what do you have to remind you that you need to grease the latch pins?:rolleyes:
And what about those of us with a grapple? Is there anyway to hook up those pesky hydraulic quick-connects without getting off the tractor?:D
Actually, I try to remember to unlatch the QA pins before getting onto the tractor. Then, I can drop the old attachment and pick up the new one while only having to get off the tractor once. Getting older as I am, I only remember to do this about half the time.:)
/ Remote Control to Release Bucket #12
I had the same thought! But I guess others had the same feeling when the first TV remotes, garage door openers, and power windows appeared, so who knows, it could be the next step forward by mankind.
Jack
/ Remote Control to Release Bucket #13
I try to plan ahead and unlatch when I am changing attachments but like Jim I frequently remember after I get up on the tractor. With my bad knees it is painful getting up.
I trying to figure out how to get an extension to the current step to add a step.
Vernon
/ Remote Control to Release Bucket #14
Yes, they do make remote operated QD's. I will look and see if I can find a web site them.
/ Remote Control to Release Bucket #15
There was a post here on TBN a couple years ago about one that New Holland offered I think? I could not find it though...I think there may have been other links in the thread also?
Hope you have better luck than me.
/ Remote Control to Release Bucket #16
This the way I remember how the QD attachment worked. The attachment had a block of steel with several pin holes, and the male connectors for the hydraulics. When the operator went to hook up, he guided the boom part which had guide pins in it for proper alignment. The pins went in first, and then the hydraulics were locked in. He could change out an attachment in a few minutes, with little loss of fluid. The pins locked the two parts together.
/ Remote Control to Release Bucket #17
What about just leaving the grapple on the loader arms?
Would that be a lot easier?
UNUSED TAYLOR-WAY 5' BOX BLADE (A62130)
UNUSED TAYLOR-WAY...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61567)
2006 Generac...
GUIGONG CLG9035E EXCAVATOR (A62129)
GUIGONG CLG9035E...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
17394SFL (A61568)
17394SFL (A61568)
(2) 10 LUG WHEEL SPACERS (A62131)
(2) 10 LUG WHEEL...
