Changing Trailer Tire
/ Changing Trailer Tire #11
I'd be woried that they would carry the weight of a loaded trailer.. anyone know weight specs? I know a layered 2x6 angled block would hold ;)
soundguy
/ Changing Trailer Tire #12
Aww here's how you need to change a trailer tire:)
Don't mind the thumb on lens:).
/ Changing Trailer Tire #13
If I can get my air jack under an axle, I can have that trailer up in 5 sec.
/ Changing Trailer Tire #14
We have used the metal Jiffy Jack and carry it with us all the time. It has been used on a horse trailer loaded with 3 horses and a pony.
Schneider Saddlery
If this link works it will take you to www.sstack their item number 08195.
We have been happy with ours.
/ Changing Trailer Tire #15
soundguy
Don't know the specs, but I've used a plastic one to change tires on a loaded 4-horse GN trailer. That'd be a similar load to a utility trailer with a CUT on it.
/ Changing Trailer Tire #16
/ Changing Trailer Tire #18
I like multipurpose tools. I just keep a few pieces of 4x4 PT in each trailer for chocking wheels or putting under the tongue jack, or for driving up on, to change a tire. They don't take very much room to store.
/ Changing Trailer Tire #19
What about the fact that you could put twice the rated load on that one tire and 50% over the axle rating? If you were at full capacity load, that's what it would be. Granted it's a static/dead load not like driving down the road, but just curious if there's anything to be worried about. Good trick to know since I have 2 dual axle trailers now.
JB.
/ Changing Trailer Tire #20
As long as there's enough air in the good tire, I doubt there's much of a problem running the good one up on a block long enough to change the tire.
KUBOTA SVL75-2 SKID STEER (A62129)
KUBOTA SVL75-2...
FORD 6610 TRACTOR (A59823)
FORD 6610 TRACTOR...
HYDRAULIC WINCH RACK (A58214)
HYDRAULIC WINCH...
Kubota MX5400 land mgmt package
Kubota MX5400 land...
2018 FORD F-250 XL SUPER DUTY EXT CAB TRUCK (A59823)
2018 FORD F-250 XL...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
