Corroded trailer wiring socket
/ Corroded trailer wiring socket #11
I use chassie grease on my connector.. works great.. sheds water.. etc..
soundguy
That's an interesting thought that water might be getting trapped inside. I've had the connector mounted with the rear (with the pins and spring-loaded cover) lower than the front (where the wires enter). I'm not sure how else I would position the connector to reduce water problems.
There's no gasket on the spring-loaded cover, so it probably allows water entry. By the same token, it seems like it should allow some drainage. Whatever's happening, I'm getting lots of corrosion.
I've attached some photos. Thanks for the continued help.
/ Corroded trailer wiring socket #13
I am in the trailer business and that has to be one of the top 2 worst looking sockets I have seen. Hate to see your chassis and other components on the tow vehicle. The stuff they put on the roads there must be toxic.
Chris
/ Corroded trailer wiring socket #14
DanG.. ditto that.. must be salt?
I'd change that sucker to a (yuck) poly job.. then grease the heck out of the pins..
soundguy
/ Corroded trailer wiring socket #15
Chris
Instead of simply using rock salt to de-ice most nothern states have started using liquid Calcium Chloride compounds [and some Potassium chlorides] as a supplement to rock salt and as a 'stand alone' treatment that they can put down before the storm.
Rock salt won't make a dicing 'brine' unless there is moisture to melt it so it can't be placed too long b/4 the storm as traffic will blow it off the dry road. It also is not effective under 20 degrees.
The first time I saw a road pre-treated w/ liquid it looked like black ice. Your entire underbody gets coated & you still see it spattering on your windshield the next day after the storm when the road looks dry! I keep getting flashed w/ high beams as I take a rag & wipe off my lights b/4 driving & they look too bright when most are coated w/ calcium.
It gets into everything! Driving the salt storage dome you now see a plastic tank and a drive under spray arm where they coat the fresh rock salt w/ the liquid.
Tractor trailer maintenace people [TMA maintenance council] is publishing warnings on the damages it is doing to the transport fleets & any tech's using a 'test light' w/ an Ice pick point is likely to be repremanded as the pin pricks they make allow moisture to enter the wiring. The corrosion wicks along the harness making a mess, this is getting worse. Most modern truck lighting uses sealed connectectors W/ sealed bulbs & sealed conncetions in gromet mounts & this stuff is STILL causing some corrosion problems.
OP's pictures show that the rear of his plug isn't sealed to well. They sell an electrical tape that shrinks like shrink tubing; It might help.
/ Corroded trailer wiring socket #16
If i lived there.. I'd fil the plug with grease after every use.
soundguy
/ Corroded trailer wiring socket #17
I use the flat 4 for the bass boat and little utility trailer and I have them up thru the tailgate in the SUV and the Pickup, no problems...
/ Corroded trailer wiring socket #18
That looks typical after 2 years here in NY state if it not used monthly and no grease used. If i use the trailer in salt months from oct to march, I find that after using the same plug after 5 years, it alot easier just replace it with spanking brand new plugs and grease it up. Otherwise everytime you hook up, you spend time fiddling around to make sure everything works before to go and it a PITA!
Wacker Neuson RD12 (A57148)
Wacker Neuson RD12...
207272 (A52708)
207272 (A52708)
1667 (A57192)
1667 (A57192)
2017 CHEVROLET SUBURBAN(INOPERABLE) (A60736)
2017 CHEVROLET...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2022 Ford F-150 Pickup Truck, VIN # 1FTMF1CB1NKE47600 (A61165)
2022 Ford F-150...
