DK45 wiring diagram
/ DK45 wiring diagram #2
We have big wall chart diagrams.
What is it you are looking to do?
Start /safety circuit W/ color/connector location.
/ DK45 wiring diagram #4
Can you be more specific. Do you want the location of the starter relay? I am looking at a Workshop manual and find nothing labelled start/safety circuit.
Everything in series with start solenoid
/ DK45 wiring diagram #6
Is this helpful?
  • Kioti electrical 20002.PDF
  • Kioti electrical 20001.PDF
I need the actual wiring schematic if you have it but I also needed what you sent me I'm trying to troubleshoot this by myself it has a cab and its PITA trying to reach everything BTW is the DK45se the same as a Plain DK45.
Thanks
/ DK45 wiring diagram #8
Thanks
I'll see if I can find the wiring schematic in the manual.
The DK45se is different from the DK45s. Also, I don't know that there is a "plain DK45" but if there is and it is related to the plain old DK40 which is now out of production...then the answer is that the newer models are not related. The current DK35se, 40se and 45se share the same workshop manual.
/ DK45 wiring diagram #9
Wiring schematic for DK35se/40se/45se. Two files are part of same diagram.
  • Kioti electrical diagram.PDF
  • Kioti electrical diagram0001.PDF
Thanks Ed those prints will help.
Ken
/ DK45 wiring diagram #11
Good luck. By the way the Kioti workshop manual for the new DK line is excellent. Not cheap at about $70 or so but well worth it if you do your own troubleshooting/service. It is really well written and illustrated with lots of info on diagnostic procedures etc.
2019 FORD F-250 SUPER DUTY (A65643)
2019 FORD F-250...
CATERPILLAR CS44B SMOOTH DRUM ROLLER (A64279)
CATERPILLAR CS44B...
Bobcat 72SDR Seeder (A66285)
Bobcat 72SDR...
2011 Ram 2500 Longhorn Laramie 5.7 HEM (A62679)
2011 Ram 2500...
2016 Ram 5500 Flat Bed (A63689)
2016 Ram 5500 Flat...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
