Modify Bottom Plow for SCUT?
/ Modify Bottom Plow for SCUT? #21
Funny how 3pt items mount, I have almost the opposite problem with a rotary mower, lifts high, but just barely goes low enough. I quess implements and tractor 3pts are not as universal as they tell us.
Since I am a visual learner, thought I'd throw in a fairly good video on how to set up and use the plow. It will give you some idea about what the gentlmen are trying to explain.
Leinbach 19-12 Bottom Plow, 3pt. Hitch Gardening, EverythingAttachments.com
That's funny - because that's the video I found on how to setup the plow.
For me, my lift arms are at full height to raise it above the ground. The video said they should be below horizontal. However, it didn't seem to effect the plowing any.
More important, was how they talked about the cutting edge needed to have full contact, and the plow leaning a little, but not too much forward. Most importantly, they also explained why.
(7) 2000 LB TRAILER JACKS & (5) JACK TURN HANDLES (A64280)
(7) 2000 LB...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2022 GREAT DANE CCC-3314-21053 53X102 T/A DRY VAN TRAILER (A59912)
2022 GREAT DANE...
15 TON GRAIN BIN (A64280)
15 TON GRAIN BIN...
2002 Freightliner Allegro Bus Class A Motorhome (A61574)
2002 Freightliner...
3148 (A63117)
3148 (A63117)
