Logging Hitch
/ Logging Hitch #101
teach,
I have various lengths of chain with a clevis hook on one end and a round hook on the other. They are stored in the ammo box mounted on the fender. I also have a proper logging wire choker too. I also plan to use a small grapple/grubber as well: http://www.tractorbynet.com/forums/projects/137965-clearing-alders-4.html
This is still a work in progress. And once I get into the woods next week I will report back on it's success.
I am hoping to finish the loader mount early next week.
Will keep you posted.
Lloyd
/ Logging Hitch #102
Spent the last two days chipping and logging for a friend. He's in the pictures - I am not.
I drove the tractor there - half hour drive. Did it early in the morning to avoid traffic.
Image 2 is the third pile. Forgot to take before and after of the first 2 piles. Image 3 is the after. Image 5 is on to the next piles. Image 6 is a closer look.
Image 8 is using the log hauler for the first time - welds held!!! Image 10 - another view.
We used the chain more so than the wire choker. The length of the choker didn't allow it to be hooked on the upper clevis hooks. Some times I used a short length of chain to get it connected. We found in the end chain worked better and allowed us to lift the logs. The ground was fairly level - so even dragging on the ground worked. We ran two 7 hour days at 2300 rpm and used 20 litres of fuel - not bad.
lloyd
/ Logging Hitch #103
lloyd
Nice Lloyd!
Looks like the hitch worked out good and nice pile of wood chips.
I plan to start on mine maybe this weekend....I've been hauling dirt and getting ready for garden season.
I found a good tree that fell over the weekend...A beech, but it will be hard to get out and hard to cut on the hill...I may have to pull it downhill if i can.
Glad you got to use yours:D__Thanks for the pictures.
Egon said he was going to build one.....i wonder if he is ahead of me.:D
/ Logging Hitch #105
When Egon does things there may be years between talk and action!:eek::eek:
Well now Egon,
You sure didn't waste no time on that been soup:D
Lloyd has left us behind...And i have a big beech tree waiting on me.
When i burn beech wood, i always make sure i have a extra grate on hand:D
/ Logging Hitch #107
Burn Beach Wood, Sacrilege I say; Sacrilege! :p
That is furniture wood!:D
Hunger is another mater!:D
:D
I would like to use it for making furniture...but...it is a ugly tree.
I have about 22 BIG wild cherry trees on my property and i just about have to guard them...every logger around here calls and wants to buy them.
/ Logging Hitch #108
lloyd
Lloyd,
With the hooks on top...How high could you lift a log off the ground??
Bill
/ Logging Hitch #109
I've been using this for several years now, It works great.
/ Logging Hitch #110
Hey Lloyd, great pics and a great job done on the hitch. Glad to see you don't have as much snow as we do here. Still 3ft of snow in the woods. I notice you have lic plates on your tractor, is that a requirement to drive a tractor on the road in NS?
/ Logging Hitch #112
jd,
With the chain the hitch will lift the logs off the ground as much as your 3pt will travel vertically - different for each tractor I would assume - less the slack in the chain. About 12 to 18 inches I guess. We tried to align the butts of the logs, than I would back up with the hitch and lower to rest on the ground and hook up. Some times I lifted the logs and set them down again to gain more scope on the chain.
dking,
I think you can get away with a SMV sign on the tractor. I had the plate on my old cockshutt and transfered it and the registration over to the new unit. They gov't no longer provides non-expiry plates. If you register you have to pay every year like a car. I figure with insurance and liability these days I would play it safe and register and get insurance for road travel. I feel more comfortable traveling on the roads. The return trip from the logging site took half hour - about 14-17kmh.
lloyd
/ Logging Hitch #113
Toadhill,
You're actually ahead of me... Out of the top 2" receiver port I would like to make an arm like yours with a hook on it.
lloyd
/ Logging Hitch #114
Toadhill,
lloyd
OK thanks on how high it will lift a log off the ground.
_________________________________________________
That would be a good ideal on an arm that would extend out.
I made this hitch extension for when i haul a slide-in-camper and pull a boat...i wonder if this would work, it wouldn't have the extra receiver on the end and i could make one a little longer.
/ Logging Hitch #115
JD,
That's my next project(work in progress) for my bucket. I did cut the angle iron, laid out and welded the three 2" receiver ports and two clevis hooks. I just need to grid, prime and paint and attach to top edge of bucket. Should be ready next week.
Now the only thing left to do is build a 2" receiver base for the vise and a few 2" receiver hooks and things...
lloyd
PS: too many ideas - and projects - not enough time!
/ Logging Hitch #116
JD,
lloyd
Do you mean have an adaptor so you can plug a vice into a receiver tube? Have the vise attached to a plate, attached to an insert tube.
If so that's what I want to do also, was just thinking about for my service body truck, my last truck had one on the bumper but didn't get used that much so I thought with the new truck just have it removable via receiver insert.
You have me thinking it could come in handy on the tractor as well, I have a receiver on the top of the bucket as well as a 3pt unit.
Thanks, JB.
/ Logging Hitch #118
Here is a receiver vise set up. Yea, I know, but when I look at it on my computer, it is full screen. Well, the top picture works.
/ Logging Hitch #119
JD,jj,jb,
Exactly. I got a record vise at a yard sale. I will mount to a base with insert tube. Now re: the truck I think I will make an adapter to fit my truck as well.
Darn TBN - too many ideas - not enough time!!! :):) Keep them coming though!
lloyd
2016 Ford Expedition 4x4 SUV (A61569)
2016 Ford...
2018 Nissan Sentra Sedan (A61569)
2018 Nissan Sentra...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61568)
2022 Mac Trailers...
Gravely 260Z 60in. Zero Turn Commercial Mower (A61567)
Gravely 260Z 60in...
2017 Ram 3500 Flatbed Truck (A61568)
2017 Ram 3500...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Peterbilt 567...
