Brush Grabber
/ Brush Grabber #1
GARBLUES
Member
N.Y.
TC30
Has anyone tried a Brush Grabber ? It looks like a Skidding Tong but has Grabbing Teeth on it. It doesn't weigh that much and I'm wondering if it's really strong enough to pull brush.
/ Brush Grabber #3
I have one of those. Use it with my pickmeup to pull out small stuff. It works awesome. I thought it would be awesome, bought it and put it to use. The only thing is you may need a mallet to hit the back end of it to force the jaws open if they bite into the tree too much. Truck and traction seem to be the limitation on it.
Definitely get the heavy duty one. It is rather "heavy duty"; heavy in the box.
/ Brush Grabber #4
I've seen these advertized before but I don't quite get why they would be any more useful than a piece of chain or nylon tow strap. You still need to get off the tractor to put them on a small tree or bush and therefore it would be the same as just wrapping a chain or strap around the tree. Where is the 1) time savings and 2) increased power/leverage etc?
The other point I've wondered is how this device would be any better than just knocking the small tree over with your FEL and then "pushing" out the roots with your bucket. I do that all the time with trees that are small enough to push over and I rather doubt this pullling clamp at the base of a small tree would provide any mechanical advantage over an FEL at six feet above the ground.
Am I missing something?
/ Brush Grabber #5
I have the HD brush grabber and it is heavey duty and it enables you to more quickly hook up and disconnect the chain or strap to pull the brush or the small stump that a chain may slip off of.
/ Brush Grabber #6
It doesn't take me more than about ten seconds to wrap a chain two or three times around a small tree trunk and hook to itself. I'd imagine a nylon strap would also be pretty quick to attach. I appreciate that the brush grabber clamps hard but if a tree is so small that it bends and allow the chain to slide off then I would imagine that same tree is small enough to just knock over with the FEL. I am still unconvinced.
/ Brush Grabber #7
I have seen it in operation, but I would rather use this or that..
/ Brush Grabber #8
Now that would save some time but costs $$$$ and would only be effective with a powerful loader. Love to have one though.
/ Brush Grabber #9
May not work for your application. I remove Multiflora Rose and it is a pain to get all the way around it with the chain, its hard enough to get in with the brush grabber.
/ Brush Grabber #10
I have one of the HD Brush Grubbers. I like it. Like someone else mentioned weight of the pulling vehicle is a limiting factor.
Solo
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
SET OF HANG ON QUICK ATTACH 48' PALLET FORKS (A59823)
SET OF HANG ON...
Giyi GY-TB47 Telescopic Forklift Boom (A60463)
Giyi GY-TB47...
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
2024 Linx 7'x20' Trailer (A60463)
2024 Linx 7'x20'...
2018 HYUNDAI VC2530152-JS DRY VAN TRAILER (A59575)
2018 HYUNDAI...
