Tiller Using my new to me tiller for 1st time (photos)
/ Using my new to me tiller for 1st time (photos) #1
DuaneW
Using my new to me KUHN EL-32-150 tiller, seemed to do a very nice job. The tiller appears to have had very limited use by previous owner. Decided to go with this one over a KK11 because of the ability to offset it in the 'unlikely' event that my little tractor gets replaced with a little bigger one. Ground was a little wet, but still was able to cut it about 4.5" deep the first pass.
In all I am Very pleased with this tiller so far, but the dealer also had the next heavier series Kuhn 72" wide for only $100 more, after using this one, kinda wishing I had gone with it. But was afraid that it would push the little tractor around in heavy clay.
DuaneW.
/ Using my new to me tiller for 1st time (photos) #2
It does seem to be doing a fine job. I hope you dont have to till all the way to the house in your first pic.
/ Using my new to me tiller for 1st time (photos) #3
That's exactly what I was thinking. I'm just a rookie here, but I'd say you need to upsize your equipment a bit. :p
/ Using my new to me tiller for 1st time (photos) #4
Bet its as big as you want,I got the 5ft kk tiller with a 30 hp tractor and it seems a perfect match. Seems to me [after using a 25 hp,lighter, tractor with same size tiller],you can go faster get more done,not having to worry to much about tractor,if your tractor is bigger than tiller,if you know what I mean. Turning a little with tiller down and tilling is an example[not going just straight,back and forth],smaller tractor you worry about bending/breaking something if your tiller is a little large for it. One thing to break an implement cause tractor is to big for it,another to break tractor cause implement is to big for the tractor.
/ Using my new to me tiller for 1st time (photos) #6
Thats what I was saying,5 ft tiller might be to big for you,6 ft,you need,what,about a 35-40 hp [heavy tractor]?
No,bigger is not always better,but on the other hand,if it works,than it works!
500BBL WHEELED...
1996 Sunflower 1543-38 Folding Disk (A61307)
1996 Sunflower...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
2016 CHEVROLET (A59823)
2016 CHEVROLET...
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
