JD 410 Loader for 4110
/ JD 410 Loader for 4110 #1
jgbanshee
Gold Member
PA
JD 310SE, 325G, 35G, 4300, 5300, 5210, 445, 450 Crawler, CAT D3B, Ford 2N, 7000, 5000, 4000su, 3610, 445D, 345C, 340B, 1100
What is an acceptable price or price range of a Deere 410 loader attachment with brackets in good shape? What did they cost new?
/ JD 410 Loader for 4110 #2
Not sure on the exact cost...but $2700-$3000 seems to stick in my head?
I would say $1500 would be a GREAT deal;)
What is the difference between the 410 and the 200XX loaders besides the curved arms? Anyone see any need to look for a 200 loader over a 410?
/ JD 410 Loader for 4110 #4
According to the specs I've read, the 410 has a very marginally higher lifting capacity than the 200X/200CX. Surprised me, I though the newer loader design would be the winner on lift cap.
What are the lift capacities if you dont mind?
/ JD 410 Loader for 4110 #6
410 loader on 4100/4110:
To max lift height at pivot pin: 882 lbs.
To max lift 500cm ahead of pivot: 618 lbs.
To 1.5m height at pivot pin: 1072 lbs.
To 1.5m height 500cm ahead: 781 lbs.
200X/200CX on 4110:
To max lift height at pivot pin: 798.6 lbs.
To max lift 500cm ahead of pivot: 556.6 lbs.
To 1.5m height at pivot pin: 1029.6 lbs.
To 1.5m height 500cm ahead: 756.8 lbs.
2012 KENWORTH TRIAXLE BODY LOAD (A67714)
2012 KENWORTH...
Mercury Outboard Boat Motor (A66738)
Mercury Outboard...
2014 DIAMOND C 45HDT CAR HAULER (A67714)
2014 DIAMOND C...
2019 Toyota Camry Sedan (A66738)
2019 Toyota Camry...
FIXED FIFTH WHEEL ATTACHMENT (A67714)
FIXED FIFTH WHEEL...
2007 HEIL TRAILER (A67714)
2007 HEIL TRAILER...
