Oil & Fuel 4025 fuel use
/ 4025 fuel use #1
joebdot
I am thinking about purchase of a 4025 with FEL that will allow Bobcat attachments to be used, I don't see the 3525 as having that flex. In what I have read, the fuel use of the 3525 is very low at least while hogging at about 1 gal per hour.
Do those of you that have experience in the use of the 4025 consider the fuel use similar with the extra 5HP? I know it is a different engine. If anyone can compare it also with the 5525 I would appreciate that as well. Thanks, I have enjoyed reading the forum. joe
/ 4025 fuel use #2
I don't know about any of those models. But my 6520 drinks about a gallon an hour. Unless I am backhoeing at full throttle.
hugs, Brandi
/ 4025 fuel use #3
my 3525 uses about 1 gal/hr brush hogging 3rd gear low range.... I only have 5 acres, with trees and ponds... can't get going too fast.
as far as the quick attach bucket I believe that is a dealer installed option available on all of the loaders, not sure though.
/ 4025 fuel use #4
I would guess fuel use would be similar. Our 5525 has 220 hrs and has used 220 gallons of fuel give or take a gallon or two. It's used with a mower- conditioner, baler, and snowblower at 2000(540 pto)rpm and between 1500 and 2000 rpm for loader work. It spends about 15 minutes a day in the wintertime idling while I shovel horse manure into the bucket. That's about it for regular usage.:)
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A64553)
2023 ASV RT-25...
2017 HYSTER H60FT STRAGHIT MAST FORKLIFT (A63276)
2017 HYSTER H60FT...
2009 Ford E-350 Cargo Van (A64556)
2009 Ford E-350...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
Star (A64557)
Star (A64557)
2026 Stout TB-76 Tri-Blade Brush Cutter (A64047)
2026 Stout TB-76...
