2320 rear wheel extention
/ 2320 rear wheel extention #1
sal64
ny orange county
jd 2320 jd 990 jd950
hello when I purchased my 2320 the dealer said ther was no optional rims to exdend rear wheels out ? I mow on hills and would like to get more stability i have r4 tires loaded .If i make two sst rings about 2.5 inches long and mount on od of wheel axal and inside of rim then used longer bolts would it damage the gearing or anything? and would it make and difference . and ideas apreciated tu.
/ 2320 rear wheel extention #2
I had the same problem with my b2630. I even emailed kubota customer service and they simply said to ask the dealer. The dealer that I bought the tractor from did not know about the extensions either. I found out about them on this website and contacted a dealer an hour away that had them. So you may want to contact messick's that is active on this site to inquire if they make the extensions for your tractor. My extensions are about an 1.5" on each side and they make a big difference.
Eric
/ 2320 rear wheel extention #3
Are you talking about a New Holland 2320? I have a 2420 and if I want to get a wider rear stance all I need to do is swap the rear wheels.
/ 2320 rear wheel extention #5
His profile say's it's a John Deere 2320...
Search the term "spacer" in the JD forum.
/ 2320 rear wheel extention #7
Ron,
The extensions were about $240 for the set. However, the spacers are just a solid piece of roundbar, with holes for the bolts, a recessed area in the back to accomodate the lip on the hub, and a corresponding small lip in the front. The studs go all the way through the extensions. There is a note that they will not work with the MMM. I have the 60" and they work fine, but it looks like they would hit the rear casters on the 72" MMM.
Eric
2000 CATERPILLAR 988F SERIES II WHEEL LOADER (A62129)
2000 CATERPILLAR...
FORKLIFT (A56857)
FORKLIFT (A56857)
2012 International 4300 Reefer Truck (A63118)
2012 International...
Lot 1001 (A64047)
Lot 1001 (A64047)
5x10 Utility Trailer (A61165)
5x10 Utility...
Trailmobile Van Trailer (A63118)
Trailmobile Van...
