2320 rear wheel extention
   / 2320 rear wheel extention #1
sal64
Platinum Member
ny orange county
jd 2320 jd 990 jd950
hello when I purchased my 2320 the dealer said ther was no optional rims to exdend rear wheels out ? I mow on hills and would like to get more stability i have r4 tires loaded .If i make two sst rings about 2.5 inches long and mount on od of wheel axal and inside of rim then used longer bolts would it damage the gearing or anything? and would it make and difference . and ideas apreciated tu.
   / 2320 rear wheel extention #2
I had the same problem with my b2630. I even emailed kubota customer service and they simply said to ask the dealer. The dealer that I bought the tractor from did not know about the extensions either. I found out about them on this website and contacted a dealer an hour away that had them. So you may want to contact messick's that is active on this site to inquire if they make the extensions for your tractor. My extensions are about an 1.5" on each side and they make a big difference.
Eric
   / 2320 rear wheel extention #3
Are you talking about a New Holland 2320? I have a 2420 and if I want to get a wider rear stance all I need to do is swap the rear wheels.
   / 2320 rear wheel extention #4
Eric what was the cost of those extensions ? I have a B2630 and also interested adding stability. Never to stable for me !
Ron
   / 2320 rear wheel extention #5
His profile say's it's a John Deere 2320...
Search the term "spacer" in the JD forum.
   / 2320 rear wheel extention #7
Ron,
The extensions were about $240 for the set. However, the spacers are just a solid piece of roundbar, with holes for the bolts, a recessed area in the back to accomodate the lip on the hub, and a corresponding small lip in the front. The studs go all the way through the extensions. There is a note that they will not work with the MMM. I have the 60" and they work fine, but it looks like they would hit the rear casters on the 72" MMM.
Eric
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
(2) 250 GALLON POLY TOTES W/ CAGES (A51244)
(2) 250 GALLON...
2011 Cadillac SRX Luxury SUV (A50324)
2011 Cadillac SRX...
PALLET OF DRAINS / DRAIN GATES (A51244)
PALLET OF DRAINS /...
UNUSED KIVEL MINI SKID STEER PALLET FORKS (A51244)
UNUSED KIVEL MINI...
2017 BOMAG BW145D SMOOTH DRUM ROLLER (A51242)
2017 BOMAG BW145D...
