JD 4020 starter wiring
/ JD 4020 starter wiring #1
lowellches
I have a late model 4020 from which someone removed the starter. We have purchased new starter - but need to know where each wire connects. Do not want to take chance of damage by wiring it wrong.
Can someone with a late model 4020 (after serial # 201,000), please take a photo ( maybe more than one) showing how your starter is wired and email it to me?
Thank you very much.
lowellches@gmail.com
/ JD 4020 starter wiring #2
i am trying to figure out how to remove the starter. any ideas? i can take a pic and send it to you.
/ JD 4020 starter wiring #3
The starter has two bolts & a nut on the backside that hold it on,takes a 9/16'' wrench.The nut on the backside is a real pain to get to unless you have on of the curved wrenches from john deere to remove it.
/ JD 4020 starter wiring #4
Hi al6798al. Do you have a Case 4020 or JD 4020? I think you are getting advice on the John Deere starter removal here...
/ JD 4020 starter wiring #5
lowellches, I have a JD 4020 but earlier. I could post some starter pictures, but sounds like you maybe are aware they would be incorrect for your later model?
/ JD 4020 starter wiring #7
texoak51
I don't know if this will help you but it's better than nothing.
2004 POLAR TANK CRUDE PUP TRAILER (A67714)
2004 POLAR TANK...
6 1/4 INCH OD 90 DEGREE ELBOWS (A67714)
6 1/4 INCH OD 90...
2014 Ram 2500 4x4 Crew Cab Pickup Truck (A64194)
2014 Ram 2500 4x4...
2009 CATERPILLAR CP44 PADFOOT ROLLER (A65056)
2009 CATERPILLAR...
2017 Ford F-550 Altec AT37G 37ft. Insulated Bucket Truck (A66736)
2017 Ford F-550...
PRESSURE WASHER (CONDITION UNKNOWN) (A68842)
PRESSURE WASHER...
