Steel for Log splitter
/ Steel for Log splitter #1
Wayne_H
Gold Member
Davidsonville, Maryland
John Deere 4400, '48 B and 318
I'm starting to scrounge parts for my next project, a log splitter. I found this peice of steel I can have for free, do you all think it will be heavy enough for a 25 or so ton unit? I may stop by home cheapo and look at the steel they use, but wonder if 8"x6.5" would work. It is 3/8" think. Here are a few shots.
Thanks!
Wayne
/ Steel for Log splitter #2
I am doing the same thing . Northern hyd has a cylinder kit 5 inch cylinder load 44000 # or so . They say use 6 WF 25# beam thats means 25# per foot. The beam measures 6.08 wide 6.3 high the flange is .456 thick and the web is.320 thick all numbers are inches . If that would work I think yours would work.
I just looked at your pictures. I think the flanges may want to be a little thicker. but I bet it would work anyway.
/ Steel for Log splitter #4
**** Yeah!!! Grab it!~Scotty (Edit: I meant to say 'heck'!)
"Free", my favorite four letter word! ~S
/ Steel for Log splitter #5
It's a good one!
Just weld some chocks (between the flanges) at the stress points and it'll last forever (or close enough to forever).:cool:
/ Steel for Log splitter #6
that 25lb pr ft will do. Don't get too carried away with multiple knives though. I have a T type knife on mine and I shoved the whole thing along with the top half of the I beam right off. I rebuilt it and fishplated the web, haven't had a problem since. I did lower the crossknife a bit. Now the knife is about 6inches tall, that took a lot of leverage away from the knife. I have sheared 6inch knots of fir and spruce with it so it should take on anything.
/ Steel for Log splitter #7
Looks like some of us are playing in the same sand box. I have the I beam and some of the other parts but Im at the part of the slide that holds the ram down on the I beam. Ill put up pictures in the morning and maybe we can all walk through this. jd
/ Steel for Log splitter #8
From the measurements in your post, that is a W8x24. A W8x24 has almost 60% more bending capacity (section modulus) than a W6x25. The flanges are slightly thinner than the W6x25, so take that into consideration for your splitter sled. Other than that, it's a good find.
Good luck.
1M21 and everyone: Thank you for the responses! And Great pictures. I was thinking that maybe the web part (the top and bottom flat part) was a bit thin, maybe 3/8" or so, but then there should not be too much force on the "pusher" on the end of the cylinder, so I hope it will be ok.
I have looked at and studied the timberwolf machines, and they are awesome. I see on all of them they reinforce the steel where the wedge is and where the cylinder sits, so I will do the same. I will also try to raise it up a bit off the ground. My axle now sits maybe 10" off the gound, and I'd prefer this was not a back breaker when using, and I was not spending all day on my hands and knees when I split. I plan on taking part of that steel, and welding that the the axle for a base, and then put the rest on top of that so it sits maybe 24 inches off the ground.
I'm going to have a log lift, it does not look too hard and only requires another cylinder and a bit more steel.
On the wedges you all have, can I ask how you make them? I've seen some high dollar ones that are 1" thick, but can I make my own out of 3/8" stock, or will they fall apart?
Regarding the pump etc, I am looking at a 4" cylinder, 9-11 HP honda, and a 22 or 28 GPM pump. I don't want this to take all day to cycle, and I get the impression many "real" splitters use 4" 3,000 psi cylinders and they work great. (with a 2" dia rod).
thanks again everyone.
Wayne
/ Steel for Log splitter #12
You should get a two stage pump . It runs lower pressure higher vol till it senses backpressure from the wedge hitting the log. Then it shifts to full pressure at the rated vol. Does wonders for cycle time.
Also a detented valve is nice. Hold it on the split motion but on the return you can let go and the valve pops to center by itself when the cylinder is retracted, If you have a 24 " stroke and you are spitting 16 " you can put a stop on the rod , they look like collars open on one end you slip over the rod. The the cylinder motion stops shorter. Problem is I have not seen one of those with a power beyond port so it is hard to add the valve for the lifter. Maybe one of the valve co Prince comes to mind can put a stack together to do that. Gets ecpensive though. I am sort of at that point myself, want to add a lifter but don't see how to add the valve.
/ Steel for Log splitter #13
Also a detented valve is nice. Problem is I have not seen one of those with a power beyond port so it is hard to add the valve for the lifter.
Sunset, just change the order of the valves. Put the lifter valve (with PBY) BEFORE the splitter valve with detent and you are good to go.:D
Mike
/ Steel for Log splitter #14
Here is what ours looks like.
My Dad built one like that over 30 years ago, but it disappeared one night when it was left in the bush. Apparently, we did not disguise it well enough.
But if you use that as the base, you will be fine.
Keep us posted.
/ Steel for Log splitter #15
Mike
Yes It came to me in the middle of the night and even before coffee in the morning I went out to look at what I had in my surplus pile. Alas 3 single spool valves but no PB on any other them. Very depressing.
2014 Toyota Tundra Crew Cab Pickup Truck (A64194)
2014 Toyota Tundra...
2006 Kenworth W900 Dump Truck, VIN # 1NKWLB0X26J138148 (A65563)
2006 Kenworth W900...
2019 COLEMAN BT200X MINI-BIKE (A64280)
2019 COLEMAN...
2019 GMC SAVANNAH 3500 14' BOX TRUCK (A65054)
2019 GMC SAVANNAH...
(4) New Caterpillar Skidsteer Loader Tires (A66408)
(4) New...
2022 KAUFMAN 4X2 2 CAR TILT GOOSENECK TRAILER (A59912)
2022 KAUFMAN 4X2 2...
