First Post
/ First Post #1
bobhere
B.C. Canada
2005 Jinma 284
Hello All, Bobhere in B.C. Canada. Got my JM 284 with a Hanmey FEL a week ago, my first tractor. Going to go over it with a torque wrench and grease gun, and do a couple mods to it. The tractor was a demo with 30 hrs on it, and i put about 6 hrs in the seat clearing blackberries away from horse riding trails. If anybody has any suggestions on grease type or oil weights, it would be welcome.
/ First Post #2
Scan this site and you'll find lots of good stuff. I used to sell lube oils, etc. I'd recommend 15w/40 in the engine, 80w/90 in the gear box, and final drive. A good E.P. #2 grease is good for these types of application, but once you go to a specific grease compound, I'd stay with it. Just my opinion.
/ First Post
Thanks for the reply. If you worked in that field, says a lot.
/ First Post #4
I must admit, however, that since all the manuals I got with my KAMA were in Chinese, , I had to ask about specific fluids, but in reality, most every diesel engine made uses the 15w/40, with very few exceptions. Rotella T is an excellent oil (what I sold).
/ First Post #6
Hi all.
Anyone know anything more about Hanmey implements? I assume they are a chinese brand?
Cheers
/ First Post #7
Howdy Bob & Everyone else. I plan to clear some blackberries on my place with my 2006 JM 284. My tractor came with a 5' boxblade with rippers. Is this the best implement to use to get rid of berry vines?
Thankyou
Jack
/ First Post #8
I just shredded mine with a rotary cutter.
//greg//
/ First Post #9
I'd vote for the bush hog as well -- I clear raspberry bushes every year on my trails with the rotary cutter . The box blade will just help them by breaking off the dead canes:p
regards
/ First Post #10
All i also have is the Spider 5' finish mower made by J Bar Corp. & I also have a 5' blade.
i just want to cut up the berry vines on an overgrown logging road to the creek.
Will this mower be ok? or is the blade better?
Thankyou
Jack
/ First Post #11
The canes are dry this time of year, so the finish mower will work too. But understand that you may be dealing with rocks in the stubble. Might want to set the gauge wheels up to the highest cut for starters. If you don't find rocks, you can always go back over at a lower cutting height.
//greg//
/ First Post #12
You will burn up the belt on your Finish Mower trying to cut the bushes with it. You really need a BushHog. Get or borrow a BH for the job then follow up with your Box Blade.
The vines will just rap around the blades of the finish mower and bind things up then burn up the belt before you know what is going on.
Chris
/ First Post #13
Chris, I'm gonna go out onna limb here - and guess that you've never cut dead blackberries. A 5' finish mower will go through them like butter this time of year. Later on the green ones will wrap, but the dead ones now - will just shatter.
//greg//
/ First Post #14
Yea, I have cut about 600' of them along my property line but never in the winter. In the summer a Finish Mower would not touch them but I guess you make a good point about them being brittle this time of year.
When I did cut them I had to back into them with the bush hog raised up slightly. Worked good for the first pass then went back over them multiple times forward to really break the up. After that we burnt the mess and planted grass to reclaim the land.
Chris
/ First Post #15
Chris
I am willing to bet Greg has never backed or pulled into a thicket of blackberrys with a finishing mower lol...... those belts ain't going to take it if they are very thick ... dead or alive !!
You can't cut grass but so high/tall with a finishing mower.
Ronald
Ranch Hand Supply
/ First Post #16
What possible justification can you come up with for wasting forum space on such a pointless taunt? You may as well open your wallet now. Or don't you realize that blackberry stalks only bear once, then brown up and turn brittle? It's like chopping up big pretzel sticks.
I got rid of most of mine with a 60" belly mower under a 24hp Yanmar - after they turned brown and dried up that is. Drive in one side, out the other. Turn around, do it again. Repeat till they're gone. Simple as that.
//greg//
/ First Post #17
What possible excuse can you dream up for wasting forum space on such a pointless taunt?
//greg//
Because it is my opinion that is true and you just confirmed it.
Ronald
Ranch Hand Supply
/ First Post #18
Yeah,I tried that once,didn't work out to good for me.
New/Unused Landhonor Gas Powered Water Pump (A61166)
New/Unused...
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
2013 Ford F-350 Pickup Truck, VIN # 1FT8W3BT5DEA61959 (A61165)
2013 Ford F-350...
2019 KUBOTA SVL95-2S SKID STEER (A62129)
2019 KUBOTA...
