JD 110 Brush Grapple recommendations?
/ JD 110 Brush Grapple recommendations? #1
two_bit_score
Super Star Member
Texas - from the brush and pear to the piney woods
John Deere 110 TLB, Diamond C 19LPX GN trailer
Hello- This is my first thread. I have been reading a while and there is a lot of great info on here.
I have a JD 110 TLB. Got a thumb on the hoe. I love it. About to get to the point where a brush grapple would be useful.
I've seen some posts on here about Markham but would like to have some actual owners/ users of Markham brush grapples describe their experiences please. If anyone has actually used a aprticular grapple on a 110 TLB that they like I'd like to hear about it.
Likewise if you have had one you particulary didn't like.
The Worksite Pro ag grapple was qouted at $2500 from a JD dealer.
Thanks!
/ JD 110 Brush Grapple recommendations? #2
I don't know how many JD owners have Markham grapples. Ask this question in the Attachments subforum and you will get a lot of positive feedback from the Markham owners. I don't have one myself but I have three years experience with a similar Millonzi light duty grapple. From my perspective you should think about a 48 inch Markham light duty version (under $1000 delivered) with perhaps some extra bottom tines. That would be about equivalent to what I have. I use my Millonzi on a 5000lb tractor with a 2700lb lift capacity and the grapple is perfect. Don't get one that is too heavy or too wide and don't fall into the trap of thinking the grapple should be the same size as your primary bucket. Simplest way to control it is with rear remotes but many guys prefer diverter valves or electric over hydraulic both which cost much more.
/ JD 110 Brush Grapple recommendations? #3
Have you tried the 48" rail pallet forks to move limbs branches and logs? I have just finished clearing 3 acres including stumps with my 110 and found that with the forks about 12 to 16" spacing was perfect for carrying stumps and set full width (48") for branches and logs. The forks will pickup and carry a load of branches big enough you cant see around them. The forks will also slide beneath a stump to pick it up where a bucket will just push it around.
Steve
Thanks, IslandTractor! I'll try that sub-fourm. I've got the extra front hydraulics for the grapple. I was really hoping to get some feed back from any JD owners with the JD worksite pro ag grapples too.
Yes, I have thought about it but thanks for providing the first hand experience. That may be a valid option. But I do like the idea of being able to clamp down on the load to control smaller pcs.
One thing I'll be doing besides brush is cleaning up some old debris sites with a lot of old scrap lumber and debris.
/ JD 110 Brush Grapple recommendations? #6
/ JD 110 Brush Grapple recommendations? #7
What I found was that I could carry a load of branches that was about three times as large as what the grapples would hold but I had to drive slower.
If you have the pallet forks or have them available I would test them out, might save you $1600. I was thinkng about grapples too but was amazed how well the forks worked for me.
Steve
/ JD 110 Brush Grapple recommendations? #10
Attachments and implements are great additions to all tractors and tlb's and I am one of the first to buy:D. When I bought my 110 with cab I spared no expense except a radio which I did not want.
If you have very rough or uneven terrain the grapples would be better to hold the load securely. Recognize that when you pickup a load with forks and tilt it back all the way that the back rest and forks form a deep vee with 4' sides. This will carry a big stack of debris. The small and or short pieces are easy to scoop up with a bucket afterwards.
Steve
/ JD 110 Brush Grapple recommendations? #11
Steve
I've got forks and a HD root-grapple. I like the grapple for digging up small trees and furrowing thru roots, etc.
Much of the dirt falls thru the tines. And it's easier to keep ahold of things once you grab 'em which doesn't always work quite like that with the forks.
I paid $2,200 for mine and they're too heavy. They're 66" and 1" tines on the bottom - right around 800lbs. I would have done better with 60" and 3/4" tines and maybe saved 100-200lbs. They'd be great if I was using them on a Bobcat S300 or S330!
Islandtractor is on the money with his recommendations - smaller and lighter - is better in most cases.
I seriously considered the JD Workpro grapple. This past Spring '08 I was quoted $1,800 for 'em. They would do the job... But, I think the tine spacing is too close together. Need about 6" between the tines - IMO.
My $0.02
AKfish
/ JD 110 Brush Grapple recommendations? #12
AKfish, I agree that smaller is better since I know that the pallet forks are only 48" wide and do a good job. I think the grapples are useful just not a cureall. I agree though there are lots of alternatives other than Deere brand.
For the roots I would think something along the lines of a chisel plow point but smaller with proper spacing would work great to pull up roots where needed. I used to have a 7 pt parabolic chisel plow that I pulled with my Case 1370 (150hp) tractor it would uncover all kinds of stuff:D I think I will make something similar to use with the 4520 but run it only about 4 to 6" deep. Basically a very sturdy and coarse rake if you will.
Steve
/ JD 110 Brush Grapple recommendations? #13
Steve
Can your forks carry a load of brush three times bigger than this?
I own both grapple and forks. Love the forks and I agree that you could indeed carry a bunch of logs or carefully stacked small trees/branches with the forks but nothing beats a grapple for being able to uproot, load and crush brush as well as whole trees and tree stumps without needing to get off the tractor. Additionally, while one can cradle a loose load with forks, it is a lot safer to contain it between the upper and lower grapple arms when traveling.
/ JD 110 Brush Grapple recommendations? #14
Grapples work pretty well for roots. I would not suggest just putting the grapple tines into the ground and driving forward on a fishing expedition but when you know there are roots in an area you can easily dig them out with a grapple.
/ JD 110 Brush Grapple recommendations? #15
I agree. I don't cruise around with the grapple in the ground just "fishin" for roots - I go to where they're bunched up..
And they're not a "cure-all", either. They're meant for grabbin' onto stuff and rootin' up and tearin' out small trees, roots, vines, brush and haulin' it to a burn pile and dumpin' it on! If that's the work you have in mind - they'll do it!
There are some things to watch out for when you're using 'em, too. Carefully pick your battles... big stumps and thick roots can unbalance the load onto one loader arm and bend or twist your loader. Either the loader arm or one of the base stancions. As well, when picking up trees - with or without the root wad - try to balance the load. The longer the tree, the longer the lever. And there are significant twisting loads exerted upon the loader arms that can quickly make one arm "a poor cousin" to the other loader arm..
Many times, I will cut the root wad off and/or cut the trees up into shorter lengths.
Ok, I guess that's $0.04, now.
AKfish
/ JD 110 Brush Grapple recommendations? #16
Looking at the pictures I can pickup and carry a larger load with forks but could not tear out and pull vines or roots loose. The lower tines on the grapple look like they would do a good job of rooting.
I do intend to clear the lots of roots up to 6" deep before preparing a seedbed. I don't intend on using the loader for this purpose though. I would guess alot depends on the condtions the OP has to deal with.
Steve
/ JD 110 Brush Grapple recommendations? #17
Looking at the pictures I can pickup and carry a larger load with forks ...
Lift yes but I cannot imagine you can load your forks with brush without getting off the tractor to neatly pile things on to the forks and then figure out some manual way of securing the load so it doesn't fall off when traveling. As I mentioned, I have both forks and grapple and I'd never choose the forks for dealing with brush any more than I'd use the grapple to lift a pallet.
/ JD 110 Brush Grapple recommendations? #18
For most of them I drive the forks forward beneath the branches pick them up at full rollback and then carry them to a trench to fill. No getting off to stack or tie down. Next time I do this I will take some pictures for you. I was suprised how well this worked as well.
Steve
/ JD 110 Brush Grapple recommendations? #19
Steve
I can see that that method would work so long as the brush was basically stacked and did not need to be moved far.
Everyone has some great points as I knew ya'll would. Thanks for helping me. Right now I'm thinking about trying the pallet forks just to see. But I'm fairly sure I'll eventually need some sort of grapple since I want to do some building demo as well as move some brush.
The JD ag grapple is about 500 lbs and has round tines on the bottom, one cylinder, and runs about $2500.
Markham has one at about $1600, plus freight. Not sure about the freight cost.
Since I have a thumb on the hoe I can load up stuff that is already stacked into a trailer pretty easily. Metal and stuff that I want to haul off.
235/75R17.5 Tire and Wheel (A68134)
235/75R17.5 Tire...
PORTA POTTY (A68842)
New - Front mount rototiller
New - Front mount...
2012 18ft Gastron Boat with 18ft Magic S/A Boat Trailer. (A64557)
2012 18ft Gastron...
2017 Autocar Xpeditor T/A New Way 31ASL 31yd. Side Loader Garbage Truck (A66736)
2017 Autocar...
2022 CHEVROLET GM515 SIVERADO 4X2 S/A FLATBED TRUCK (A67737)
2022 CHEVROLET...
