Just bought a boom pole
   / Just bought a boom pole #21
I just got an old MF 50 this weekend (first one I've owned). I bought it in the home town of "The Andy Griffith Show". I'm making a jib for the three point hitch so that I can lift some timbers. I need it to work on a sculpture I'm making, not to mention bush hogging the pasture. This is the image that I'm working off of. I think it is Australian made.
I'm not sure if I'll put that bend in it though.
   / Just bought a boom pole #23
I picked up a boom pole when I got my tiller. The tiller weighs about 700# and I didn't think the FEL would reach over to the center of the trailer bed without bonking into the trailer wheel first. Plus, I didn't have any hooks on my FEL at the time. The boom pole made unloading easy.
That boom pole gets a lot of use. It's great for all sorts of lifting and dragging tasks and makes a dandy little brush hauler. When I'm clearing brush or limbing a tree I lay a choker chain out and stack the limbs across the chain with about 2 feet of the butt ends hanging over. When I'm done I gather up the chain, cinch it, hook it to the end of the pole, lift, and away we go.
Haven't tried the logging tongs on it yet - maybe this weekend if the ground stays hard.
-Jim
   / Just bought a boom pole #24
Nice boom pole.. Just a suggestion before you attempt to lift anything heavy. I'd run something solid across the top like you see on most boom poles. Right now the load will be compressing the supports you have welded underneath. If you weld on top, the load will pull that part into tension. Much stronger. Just my thoughts.
I did some more work on the boom pole,
I lined the piece of pipe with another 10ft. piece of pipe, it was so tight i had to take a sledge hammer and drive it all the way through.
It likes 3/8 of an in. to be a solid 10ft. piece.
   / Just bought a boom pole #25
The boom poles are pretty handy for picking up a drag on the turns too. Not to mention not having to leave it in the field. (Or tearing up lawn getting it back to the shed or coral.)
   / Just bought a boom pole #26
Bob in Va or others, how did you attach your boom pole in your FEL bucket? I don't have a welder but had thought of straps, chains and binders. Later this summer I hope to start work on a pole barn and was considering lifting the trusses in place with the loader bucket and boom pole.
   / Just bought a boom pole #27
I bolted a hitch on top of my bucket, i really didn't want to weld it.
I move trailers around a lot and keep the backhoe on most of the time, so i decided to put the hitch on my bucket.
I took a piece of pipe and made my boom pole, i took another piece and put it on the end to make it tighter in the hitch.
When i built my garage i didn't have a boom pole, so i took a piece of pipe and strapped it on and had to lift the trusses up 12ft, it worked but this way will be better, and I'm planning on another build this summer.
Here is a picture how i mounted mine.
   / Just bought a boom pole #28
Speaking of boom poles, I reconfigured this one to mount on the front of my Power-Trac. Works real well. Can reach up as high as 16 ft. It can still be used as a 3PT boom pole.
   / Just bought a boom pole #29
That looks like a strong built boom pole.
J_J
I didn't hardly recognize you in your avatar, did you grow that overnight.:D
   / Just bought a boom pole #30
J_J
The boom pole is well made, and I was thinking of modifying the end piece with some hitch type tubing. I want to mount a hydraulic chain saw on the end.
As far as the beard, that was my Christmas look until a couple of weeks ago. until I trimmed it back some.
Pallet Fees (A50774)
2022 CASE TV370B SKID STEER (A51242)
2022 CASE TV370B...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A51039)
2023 New Holland...
2002 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2002 Ford F-150...
2013 MACK GU813 GRANITE ROLL OFF TRUCK (A50854)
2013 MACK GU813...
2013 Mack GU713 T/A VacCon Combination Sewer Jetter Vacuum Truck (A50323)
2013 Mack GU713...
