Another waste oil burner.
/ Another waste oil burner.
Train
I think I know what you are saying. I had the oil level higher in the short tube bit the pipe got hot enought to catch the suface of the oil on fire and then you have ash and gunk buildup problems. In that picture the oil level is just high enough to allow some airflow through the pipe to cool it. Plus the oil level over the jet be must be in the thousandths like maybe two or three, very fine control is needed. I did make one out of 3 inch exhaust pipe for a bigger pool of oil and made a heat shield over the oil with a hole for the jet and I still had stability problems. The one guy I saw making the verticle work was using a 10 inch pool of oil in a custom cast conical kind of deal.
/ Another waste oil burner. #12
Bernie, on your vertical, what were you using for air pressure and what size was the hole in your nozzle?
The hole is .010
I tig welded a little piece of metal over the end of a brake line then drilled it.
Broke about 5 bits till I got it right.
Air pressure varied between 30 and 60. I think for that rig it was best at about 40 or so.
You may have found this already but..
Here is the forum discussion that got me interested int the vertical setup.
Biodiesel & SVO discussion forums
You have to join to see the pictures but it is free and worth it.
Of course if you google Babington burner you have months of reading to do.
1996 Dorsey Enclosed Trailer, VIN # 1DTV11520TA252324 (A57453)
1996 Dorsey...
Hustler super Z zero turn (A56859)
Hustler super Z...
1998 POLAR TANK (A60736)
1998 POLAR TANK...
2014 FORD F-450 XL SUPER DUTY SERVICE TRUCK (A59823)
2014 FORD F-450 XL...
40' 6 Door Shipping Container (A60352)
40' 6 Door...
2017 BX2680 Sub Compact Utility Tractor (A61307)
2017 BX2680 Sub...
