Engine Make for '07 T7030?
/ Engine Make for '07 T7030? #1
Jaxxson
London, Ont, Canada
Case 450CT
I am wondering what make of engine is in my 2007 T7030 NH, Its been bugging me all week, is it a CNH inhouse engine or is it a cummins? I know its a 165HP engine, but thats all i can find on it, NH's website is useless for engine details.
Thanks,
Jaxxson
/ Engine Make for '07 T7030? #2
Is there a tag on your engine? I wonder if that uses the Iveco? That's what I'd bet on.
I didn't seen one when I looked, it wouldn't be ontop of the block would it?
/ Engine Make for '07 T7030? #4
I have seen tags on the valve cover before, not a good place in my mind. It may be painted over. Have you checked with your dealer? I'm sure someone here will know though.
/ Engine Make for '07 T7030? #5
I may be wrong but I think that the 6.7 liter engine in your New Holland tractor was the result of a joint venture between Cummins and Iveco. I have heard that the Cummins 6.7 engine and the 6.7 engines in New Holland & CaseIH tractors share similar architecture but are not completely the same engine.
Yes, I was correct. (I decided to look it up.) The European Engine Alliance was started by Iveco, Cummins, and New Holland in 1996. It was disbanded in July, 2008 when Fiat purchased Cummins' 1/3 share in the joint venture and Cummins agreed to buy Fiat's 50% share in the North Carolina CDC plant (originally formed by Case Corp. and Cummins in 1980).
I guess since your engine was built in 2007, you can call it whatever suits you best.
/ Engine Make for '07 T7030? #6
/ Engine Make for '07 T7030? #7
A lot of medium size Iveco trucks (180 to 250 hp, 7.5 to 18 ton) have an Iveco badged Cummins 6BT or QSB 5.9
/ Engine Make for '07 T7030? #10
At one time, they sold a few, but they didn't seem to go over here too well. There is no distribution in the US at this time.
Ya it does say Made in Uk on spots......but then again, almost every part that says where its made is made in a different country. They should of said Assembled in UK
2014 Chevrolet Tahoe SUV (A64557)
2014 Chevrolet...
2012 Komatsu PC200LC-8 Hydraulic Excavator (A64194)
2012 Komatsu...
2013 FORD F-150 (A65643)
2013 FORD F-150...
Linx EQ7018RS Trailer (A65640)
Linx EQ7018RS...
2015 Ford Taurus AWD Sedan (A64557)
2015 Ford Taurus...
2019 PETERBILT PB337 LUBE TRUCK (A63276)
2019 PETERBILT...
